O2 Sensor problems - Yikes!
I was replacing my O2 sensor today and when I went to unplug the boot that connects in the left side of the engine bay the piece that the sensor connects to came with it! I don't know the name of it and I need to replace it. Does anyone know how, where, what I'm looking for? To recap - it's NOT the sensor itself, it's the piece that connects to in the engine compartment. I can post a pic later if it helps.
1983 SC - sold 2002 996 C4S - sold 1968 912 |
Is this the problem?
O2 sensor lead from harness has broken off.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
BINGO!
Thanks! This site is AWESOME!!!!
Band.
Welcome to the club! Pretty much every o2 car owner is in the club.
Clip what's left of that connector off, put a spade terminal (or similar) on it, and clip the thing off the end of the o2 connector and do the same. Connect, and Voila! You're done. I zip tied the new connection I made to a hose or harness so it's easily visible, should my wrench ever need to disconnect my o2 sensor.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
grateful user
as others said, but do not use solder to join as it will effect the milli voltage that travels that wire
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Member 911 Anonymous
ALso insure the metal shield is properly insulted, it also cause havoc to the ECU. I use heat shrink on mine.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
