Well I am elbow deep into my Clutch replacement.
So while waiting for the Flywheel resurface, I am replacing the shifter bushings...the cup and linkage one were fine, but what is the deal with the coupling pair? How do I get the old ones out? Do I hammer the pin out? I am confused...thanks for any advice... I can't wait to see how my 915 feels with a new Sport Clutch, new shifter bushings...etc... I may have to treat myself to a brand new shift knob! |
![]() A little Wd40 and just hammer the pin out. Make sure you support the coupler while striking the pin. The coupler is cast and might bend. Just did mine and I could not believe the difference it made. Joe 78 SC |
I used a piece of 1/2" diameter aluminun, rod to drive out the steel pin with no damage. It came out without having to be hit too hard.
------------------ Allan Broadribb '70-911E, 2.2l with Webers http://www.cheaterswayside.com/uploads/Mvc-002s355.jpg |
There is less chance of damaging the coupler body if you use a large bench vise, and a couple of sockets to press the pin out! On one side put a socket larger than the OD of the pin, and on the other side put a socket (1/4" drive) with smaller OD than the pin.
------------------ Warren Hall 1973 911S Targa |
Thread Tools | |
Rate This Thread | |
