Platform for Engine Removal
Having just completed my 915 rebuild. I now plan on installing my "new"transmission.
I'm at work today and bored so I decided to build a platform for my upcoming engine drop. I plan to buy an ATV jack and place this platform on it. Will this work for an SC 3.0 engine. Any changes I should make. I kind of adapted this from previous posts.
Matt. 83 911SC 85.5 944 NA - Sold |
Designer King
That looks interesting, Matt. Can you provide the dimensions?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Immature Member
Balance is key. Just gotta find that center of gravity so the engine/tranny unit balances on it. With an ATV jack it's so much easier as the weight is distributed on bunks and tipping isn't so much of an issue. Just get it low enough to clear the rear valence/bumper and your home free!
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
The older SC has a round flat surface under the engine where the oil drain is. Your 83 does not so you need something to keep it steady. Although, when I had a 84, I just used 2 jacks.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
My 83 has the flat sump plate, not the newer style like the 3.2. I think it was somewhere mid year they started using those on the 83 SC.
Replace the wood blocks with casters....that way when you lower the atv jack down you can roll around your engine. Thats what I did and it has been great.
Darren 1973 911 T MFI 2005 997 Carrera 2001 Toyota 4Runner |
Here you can see the platform
Wer bremst verliert
After many engine and transmission drops/installs I finally sprung for a "lift table." It is very heavy steel construction with TUV approval and an integrated hydraulic jack. Goes down to ~7" and up to 48."
Now I wish I had done that to begin with. ATV jack with a platform will be helpful but tey arent the most stable when rolling around and that platform should be bolted to the jack.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Lift Table specifications
JohnJL,
Can you post the specifications, or at least model number for your lift table? A picture would be a great help. Sounds like the best plan if it is not possible to raise the car very high. Tom 912e |
Bland
Don't waste your time, this is by far the best system... you don't even need to jack up the car...
![]() All we had was a forklift and the car on my flatdeck and some crazy siberian guy...
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Home of the Whopper
I use something like this:
![]() A 2'x2' piece of 1" plywood screwed to 4x4s on casters. Just tall enough for my standard 3 ton jack to roll underneath of it.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
