Member 911 Anonymous
Hey Fellas,
OK, I am really pissed, ![]() I gained access to my Center Vent Housing Tube thru the trunk and LIKE a RETARD, I pulled all the wires from my Fog Light Switch because there were all twisted up. The real retarded thing was I when I figured I could depended on Bentley Manual and Haynes to guide me to the correct connections and wire color. WRONG ![]() Per both manuals, the diagram calls for 4 connections on back of the Fog Light Switch 911.613.149.00: Black/Blue Line to terminal #58 Brown to terminal #31 Grey to Terminal #15 (this connector had a piggy back male connect sticking out the side) Blue/White line to terminal #1 Then here is the CRAPPY part a mystery wire: Grey/Yellow Line wire WTF? ![]() I know it goes on the back of the switch because it was the part of the cluster of wires I pulled but WHAT the HECK! Tried the first setup of only 4 wires. Popped 20 fuses. What a PITA. Noticed the Central Locking button did no light up, OK so I have something screwed up. Then I connected the Grey with Yellow Stripe to the Grey wire on Terminal #15. Voila, Central Locking Button Lights Up. But I keep blowing fuses, ran out of 16Amps and starting to go thru all my 25Amps. Does anyone have a Clue on where that Piece of Poop Grey/Yellow wire goes? Or is my Switch Shot? TIA Pic of the PITA FOG LIGHT SWITCH $53 at Dealer: ![]() Yes I tested the light within the knob, it lit when I put a 9 volt to it. Relay click when I jiggled the switch around. but keep popping the #8 fuse.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks Gerry!!!
Oh Brother Gerry,
Thank you so much, I really appreciate your post. OK, you found an extra wire (1,5 GR) but it does not have the dreaded YELLOW Stripe. Hmmm. Could I ask a major favor, can you see where that extra line goes to? I assume your baby 86 also has a Central Locking as my 85 since it was the year it was introduced. Jim ![]() BTW, does anyone know what is the meaning of the codes 0,5 1,0 1,5? Is that the thickness or guage in PAG Language?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-27-2009 at 02:11 PM.. |
Oops nevermind, opened my eyes to see the 1st jpeg. Thanks Gerry, yet again.
Well I tinkered around with the switch. Per diagram and when I opened it, there was a little capacitor. I think I blew it.
When I plug it back it and turn on the lights it does not light anymore but still blows the fuses. I just ordered a new switch. I guess popping the fuses 20 times did that sucker in. Oh well. 3 days and I get a new one and this time I will plug the sucker in correctly. The only thing is that damn GR/GE line. Damn PAG!!
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-27-2009 at 02:40 PM.. |
Emailed you Gerry.
OK, looking at the diagram, the only GR/GE is ashtray light coming out of the Light Switch, OK now I am totally confused, how the heck did that wire end up on the damn Fog Light Switch? OMG kill me now!
0,5 , 0,75 , 1,0 , 1,5 etc are wire thickness in mm2.
0,5 is aprox 20 AWG 1,0 16 AWG 2,0 14 AWG Also take note that Europeans use a comma instead of a decimal point. |
Gracias Don Porfi
Update.
Finally narrowed it down to a defective Fog Light Switch and a Lost Grey Wire. Turned the Grey/Yellow as a 12 Volt source from Fuse #7. Once new Fog Light Switch comes in I will test it again. In the mean time, I bypassed the Fog Light Relay and placed the two Fog Light Wires to Fuse #7 and an 8 amp fuse. I actually like the fact the Fog Lights turn on when Parking Lights turn on. If I keep this set up I am going to place a relay for safety and less strain on the light switch. Or I could connect the Blue/White wire to Fuse #7 and reconnect #8 and the two fog light wires on #8 as PAG designed. My Fog Light Switch can be by passed only. So #8 Fuse and Fog Light Realy are disabled until the new Fog Light Switch comes in. A Million Thanks to Gerry for the crash course in EE. Jim P.S. I take back what I said about PAG. It was the POS that messed things up.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-28-2009 at 05:36 PM.. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
You are welcome.........
Hey Gerry,
I tried to remove the thread, but once people post, the thread becomes permanent and unless a Moderator decides to remove it. Jim
Threads.
A member can only remove his/her own posts.
And as you posted, not the thread. However, if all of the posts are removed, perhaps the thread will also be removed. |
Update:
Replaced the Fog Light Switch. BINGO The new switch was less sloppy/loose. The only thing is for some crazy reason my Fog Light Harness/Bundle has the Grey with Yellow Stripe instead of the Grey. Also I relocated the Fog Lights to come on when I have the ignition on. Very pleased, that I can run the fog lights as Day Driving Lights. If was helpfull this morning when navigating thru freeway traffic. Once again thanks Gerry! I owe yeah.
so your foglight can be on with all lights are off?
Fat butt 911, 1987 |
Yes, like day time running lights
