scotricker's Avatar
What about using Ramps?
Can I use ramps with this car? Or just jack stands? Is there clearance?
Anyone tried it?
Scot
78 911SC coupe, sold,, 2019 Macan S
"my friends all drive Porsches, I must make amends.."
Old 08-11-2009, 08:46 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
I have 3 different sets of ramps, the approach angle of the 911 bodywork precludes them from being used. Jackstands!
eric
P.S. You could make some ramps from 2X12s and angle them appropriately to clear the body.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-11-2009, 09:31 PM
Oracle's Avatar
I use those black rhino? ramps sometimes, like when I changed the engine mounts or to do a valve job.
If you can't put then in front of the wheel try the back, sometimes the body interferes with just one side or just slide a 2x4 to make some clearance.
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 08-11-2009, 10:17 PM
T77911S's Avatar
i have a set. very much a pain to use on both the volvo and the porsche. i have to put these 2 inch blocks of wood in front to raise the cars up so the spoilers dont hit the ramps. to make it worse, they all slide across the floor when i try to drive up on the wood. anyone want a set of ramps?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-12-2009, 04:05 AM
My standard ramps work just fine, if I put an ordinary brick at the base of each one to raise the car for the initial approach,and I have an IROC air dam--pretty low in front. I use the ramps on the driveway--don't have a garage--which is grainy enough to keep them from sliding.
Ramps will slide no matter what you do if you use them on a smooth floor, unless you do something like sinking big masonry bolts into the concrete to keep each ramp from sliding. But then you'd need to do that somewhere that doesn't require you to drive over the naked boltheads every day, so that may not be possible.
I would much rather trust good ramps to be stable rather than jackstands.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 08-12-2009, 05:30 AM
(the shotguns)
berettafan's Avatar
i have those rhino ramps as well but it seems like most of the time when the car is in the air i'm pulling wheels so they just sit.
Old 08-12-2009, 05:40 AM
