chocolatelab's Avatar
compression test numbers
Hi all
Well I decided to have a local porsche shop do the work on the broken head studs. Just dont have the time and room to get it done myself. I promised myself I'll do it one day. Just not this car this day.
Anyway.
One head stud each on 2 cylinders left side broken.
78 sc with 77k miles.
Just got my compression test numbers.
all cylinders but one tested out around 130. Cylinder number 2 tested at 100-105.
Any thoughts from the Pelicans out there?
1978 911sc Targa Sold 2001 996 Cab Sold
2006 Cayenne S Silver Wifes Car for sale
2011 Jeep Wrangler Silver for sale
2010 Toyota Prius Black for sale
2016 BMW 328D wagon
Old 08-12-2009, 03:17 PM
I am no expert, but those number are on the low side.
You might need to check the wear on the P&C's.
I would get a second opinion from a reputable shop, though.
1986 Targa
1968 MGB (2)
Old 08-12-2009, 06:25 PM
nineball's Avatar
from what i read on this board you want them to be around 150, but don't quote me.
Old 08-12-2009, 09:41 PM
Compression Test Pressures
Cylinder #2 is a problem.
Old 08-13-2009, 11:40 AM
scarceller's Avatar
Have them do a leak down test as well.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 08-13-2009, 12:03 PM
SC-targa's Avatar
These numbers are pre head stud replacement, right?
Are you planning on a valve job while you've got the heads off?
Not sure what you're asking.
Regards,
Jerry
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 08-13-2009, 01:47 PM
no expert. But I think american spec engine. has lower commpression on cylinders. I think 130 is normal! 150 to 160 on euro spec engines. But I could be wrong.
Old 08-13-2009, 01:52 PM
scarceller's Avatar
The 130 isn't the big issue here, it's the the other cyl that's way off down near 100. A leak test will really help give more info on the condition of the cylinders.
The low cyl could be something as simple as a bad Valve Gap or a dirty valve. You want to try to figure out if the low compression is Head/Valve related or Cyl Piston/Ring related
Sal
1964 356SC (SOLD)
Old 08-13-2009, 02:12 PM
As my table in the link shows, 130 is correct for a 8.5 CR engine and 150 would be more correct for a 9.5 CR (1980+).
Old 08-13-2009, 07:51 PM
mark waller's Avatar
Send a message via AIM to mark waller
Who did you go to? I emailed a couple of Great shops. Is it at Tom's in Temecula? Hope it works out!
Old 08-13-2009, 07:58 PM
Yes these are pre head stud replacement numbers.
I will be visiting the shop again tomorrow to see how things are getting along.
We will be doing leak down.
I am asking because I want to be as informed as possible when discussing issues and such with the shop.
I will be taking pics and will post.
I really am relying all your assistance to make sure I make the best decisions possible.
Thanks for all your help.
2016 BMW 328D wagon
Old 08-13-2009, 09:30 PM
scarceller's Avatar
Was the engine dead cold or warm when compression tested? Both cold and warm test could be useful but the warm test is best.
In the end you really want the shop to try and figure out if this a Cyl/Piston/Rings leak or a head related leak so you can decide what's the best approach to resolving this.
If the broken/loose stud is on the bottom it is possible to repair in car (not easy but possible). You need to remove exhaust system then pull alternator with fan so you can get the air tins out from between the cylinders. If you can get these out you can then see where the stud is threaded into the block. I'm not 100% certain but I think you may be able to get the stud out and then the hard part is inserting the time-sert to repair the bad thread (DO NOT use a helicoil use a TimeSert repair kit) I have repaired these threads before but never in car. However, I do think it may be possible to do the lowers in car.
If it's a lower I'd try fixing the stud(s) in car then drive the car some more and retest comp after a few 100 miles.
Sal
1964 356SC (SOLD)
Old 08-14-2009, 06:53 AM
Engine is out.
They should have it disassembled shortly.
all questions will be answered then.
Another question. The clutch measured at 6.5. Brand new is 8.
How much life do you all think is left.
2016 BMW 328D wagon
Old 08-14-2009, 12:22 PM
Fast Corners's Avatar
Chris,
According to my spec book new was 8.1 mm and the wear limit is achieved at 6.0 mm as long as the wear is even. Maximum runout is 0.6mm. Given this it would be prudent to replace it while the engine is out of the car.
Interesting to me is the car has 77K miles on it and this is most likely the 2nd clutch disk. What does the date stamp on the disk indicate?
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 08-14-2009, 02:21 PM
Not sure can find out though.
Here's what i have on the clutch from the previous owner.
In 1995 at 62 k miles the clutch was adjusted,replaced fly wheel and flywhhel seal
this is not a daily driver and probably wont see another 5k miles this year.
Any ideas how long it should last? I am sure that is totally dependent on the driver but ballpark?
2016 BMW 328D wagon
Old 08-14-2009, 08:39 PM
My 78 euro 3.0 L tested out at 165,165,165,165,160,155
Old 08-19-2009, 07:16 PM
1980SCMan
Alan Lindquist's Avatar
My 1980 SC was tested at 128 (approx) all around except for #2 which was about 95. That was 2005 with 125K on the motor. I've commuted daily and driven it hard but not abused it for 75K miles since then. Now cyl #2 test out as "going along for the ride" as my mechanic puts it. Oil consumption is about the same - 1 qt every 1200 to 1500 miles depending on the outside temperature. Head studs are tight. Oil filler shows puffs of smoke when the cap is removed, so I'm thinking wasted rings. Still runs. Will keep running it and wanting to put a 3.2 in soon.
Old 08-19-2009, 07:54 PM
that is pretty impresive.
they are going to replace the rings since its all out and not too expensive.
It probably just makes sense to put it all back to gether after that just drive it.
2016 BMW 328D wagon
Old 08-19-2009, 08:13 PM
