fzr1k's Avatar
82 911sc cis problems
i have an 82 911 sc coupei just bought with 65 k on it. when i got the car it ran the first time i drove it after about20 miles it started to miss and cut out them caught the heater hose on the right manifold on fire. then after repairing the carnage (burnt cam tower oil line)the car ran fine. drove it for half a day stopped at a store started the car and drove 1/4 mile car started to miss and cutout then died. it tryed to restart for a while then no spark so i replaced pickup coil installed msd 6al box and 8202 blaster coil car fored right up but ran rough so i changed plugs and made new wires with tayler thundervolt 8.2 wires reused old plug caps.car ran great reset timing took for a test drive seamed ok the it started to cut out and got worse and worse till now it does it all the time except when idling.please help.
Old 08-13-2009, 01:44 PM
Peter Zimmermann's Avatar
Dirty gas tank? Remove the sending unit (under the carpet near the brake booster and filler pipe from the gas filler cap that connects to the top of the gas tank) for the gauge and look through the opening with a flashlight... The sending unit has five small nuts, and pulls straight up from the tank - do it slowly so its tube can drain as you remove it.
Keep the Shiny Side UP!
Pete Z.
Old 08-13-2009, 02:37 PM
mca mca is offline
mca's Avatar
How would the heater hose catch on fire? Can bad / arcing cause that?
My bet is that the problem is ignition related rather than CIS related based on what I have read so far.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 08-13-2009, 02:49 PM
fzr1k's Avatar
i think it leaned out it also made the rear bumper very hot
Old 08-13-2009, 05:04 PM
Porsche Crest
I'll bet you burnt your rotor you need to get one without a resistor. Search "rotor". Your MSD has a much hotter spark and the original resistor style rotor will burn out, especially if your wires are arcing which I would bet they are. Replace your rotor with a solid one and then run your engine in the dark and look for arcing, you can also listen really close and you can hear clicking if they are arcing. Or, just (really don't do this) run your hand along each wire you'll know when you find it.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 08-13-2009, 05:33 PM
fzr1k's Avatar
well i drained the tank i looked great inside and the strainer was clean. i checked my fuel pressure it was 60 psi 5 less than spec but really shouldnt make that much of a differance but i think i might not be getting volume.also i think the accumulater is fine as i can crack the system when its off the shut it and build pressure back to 30 psi again which is what it is static. i checked my rotor i have the 5 ohm in my car and it is fine. i have a bentley service manual which shows a volume test but i havent tried yet. i forgot to mention that my car idles perfect b ut is a little slow to start.
Old 08-16-2009, 04:13 AM
T77911S's Avatar
you said it idles fine? could be sticking plunger in the fuel distributor. did the car sit before you bought it? also check control pressures
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-17-2009, 06:06 AM
fzr1k's Avatar
yes it did sit i think i have to much fuel pressure it now runs better but bogs just off of idle
Old 08-17-2009, 06:49 AM
