Eck Eck is offline
Engine Install issues
I had to pull my engine to fix some oil leaks (78 SC). I just reinstalled it and now when I start it it revs REAL high, how high I don't know, because once I crank it and it starts it jumps up to 5000 rpm and I think would keep going so I quickly shut it down.
Now while I was in there I removed the air pump and backdated the heat. I also noticed that my decel valve does not nor never did have a hose connected to the top. Any ideas?
Kirk
Old 08-18-2009, 06:35 PM
check ur accelerator linkage, maybe?
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 08-18-2009, 07:18 PM
muck-raker
kidrock's Avatar
+1, sounds like binding linkage.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 08-18-2009, 07:26 PM
Butterfly valve position........
ECK,
Inspect the position of the butterfly valve in the throttle body. It should sit close when engine is not running. In your case, the throttle linkage is some what binding and preventing the butterfly valve to close properly.
Tony
Old 08-18-2009, 11:47 PM
Wer bremst verliert
JohnJL's Avatar
As mentioned check your linkage, then suspect an unconnected vacuum hose resulting in a big leak. Your brake booster hooked up? Thats a massive leak.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 08-19-2009, 03:36 AM
gathomas's Avatar
+1 Vacuum leak somewhere
Old 08-19-2009, 06:39 AM
