Best way to clean nuts and bolts
I am trying to clean up various screws, nuts and bolts on my SC. The usual accumulation of a little corrosion, over spray and road grime. I initially had great success with a product called "CLR" that I bought at the hardware store but then I realized it stripped the cadmium plating off within minutes. Can anyone recommend a better method other than buying all new fasteners? Cheers, John
Old 08-23-2009, 04:37 AM
DUK DUK is offline
DUK's Avatar
I've used a vibrating tumbler. I beleive it was from harbor freight or northern tool.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 08-23-2009, 04:48 AM
mca mca is offline
mca's Avatar
Brake cleaner and a rag.
Old 08-23-2009, 05:16 AM
David's Avatar
I use the gallon can of Berryman's carb cleaner. It's not the same stuff as the spray can.
Old 08-23-2009, 05:28 AM
Wavey's Avatar
Brake cleaner and an assortment of small, stiff, non-metallic brushes.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 08-23-2009, 06:19 AM
Dave Nordhoff's Avatar
Laquer thinner in a coffee can, works for me.
Old 08-23-2009, 06:33 AM
al lkosmal's Avatar
replating gets them nice and clean
I like re-plating....they get very clean.
RGruppe #669
http://www.x-faktory.com/
Old 08-23-2009, 07:54 AM
Industrial Grade Tool
WoodSport's Avatar
In case anyone is thinking about ultrasonic cleaners: they will remove plating and will even erode the steel if the parts are left in long enough. I learned that one the hard way.
/Jon
Old 08-23-2009, 07:56 AM
T77911S's Avatar
thats what i use too. it WILL take the paint off anything you leave in there too long.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-25-2009, 04:46 AM
(the shotguns)
berettafan's Avatar
i use a brass wire wheel. nice clean threads.
Old 08-25-2009, 06:14 AM
DanielDudley's Avatar
Get a little strainer, and a can that it will fit into. Use the solvent of your choice, and jiggle the strainer. Self draining, but dump into a rag or paper towel.
I too am a fan of a wire wheel on a grinder for cleaning up threads and surface rust.
Old 08-25-2009, 04:06 PM
Shaun @ Tru6's Avatar
Al, who did your plating? In what condition did you send your parts?
Tru6 Restoration & Design
Old 12-18-2009, 05:25 AM
sancho
sancho's Avatar
brake cleaner as well, works great
1980 SC targa blue-SOLD
1986 Carrera wide body white
Old 12-18-2009, 06:43 AM
al lkosmal's Avatar
plating
Electrofinishing Inc: Plating Anodizing & Electropolishing
22630 88th Avenue South, Kent, WA
(253) 850-0540‎
I used the company listed above. Several of us, in the PNW, have gone to Electrofinishing Inc. and are pleased with the results. I brought my hardware down there in all forms......some clean, some oily, greasy, etc. They will charge accordingly. As long as you don't have "long" parts that will hang up on their plating equipment, they will plate your parts in a batch. Fairly economical for nuts, bolts, small sheet metal parts like I've shown in my pix, but the price goes up quite a bit for larger parts.
Regards,
Al
RGruppe #669
Old 12-18-2009, 07:35 AM
John,
Call Rennsport and ask if Brian has a batch of bolts needing to be replated anytime soon. He does a batch every so often. If so, maybe you can throw yours in with his...
JR
Old 12-18-2009, 07:38 AM
Senior Member
Superman's Avatar
I use Mequiars degreaser, which is available in gallon jugs in auto paint stores. It is red. It does not seem to attack cadmium plating. Everything else does attack the cadmium. The Meguiars is good stuff. In a coffee can or peanut butter jar.
Mocha 1978 911SC. "Coco"
Old 12-18-2009, 08:20 AM
Roc Doc's Avatar
This is good stuff. I also have a single burner propane camp stove and an old pot in which I boil the fasteners first. It doesn't take long, and it often gets off all the muck without resorting to chemicals, or at least softens it up enough that a brass brush will clean them up.
1976 911S Targa, Carrera bodywork, 3.2l engine.
Old 12-18-2009, 08:59 AM
Let them soak in kerosene
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-18-2009, 09:45 AM
my nuts are dirty too
Old 05-03-2011, 11:48 AM
tumbler
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-03-2011, 11:53 AM
