RRD RRD is offline
speedo stops when dash lights on...
OK, the speedometer in my 1988 930 stops working when the dash lights come on; really. The needle drops to "0" as soon as the guage lights up. Anyone have any ideas??
Thanks,
RD
Old 08-19-2009, 06:57 PM
Sounds like a weak common ground connection somewhere behind the intruments
Old 08-19-2009, 07:00 PM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
RRD,
I got your pm, I have a similar problem...works without lights on but doesnt give accurate reading.
what are the voltage ranges for the signal wires? it would be easy to test if I am getting a signal.
JF,
I can rewire a ground easy enough, ill try it out
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 08-24-2009, 03:29 PM
dshepp806's Avatar
Yes,...ground checks first.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 08-25-2009, 04:57 PM
