speedo stops when dash lights on...
OK, the speedometer in my 1988 930 stops working when the dash lights come on; really. The needle drops to "0" as soon as the guage lights up. Anyone have any ideas??
Thanks, RD |
Sounds like a weak common ground connection somewhere behind the intruments
Black and Blue
RRD,
I got your pm, I have a similar problem...works without lights on but doesnt give accurate reading. what are the voltage ranges for the signal wires? it would be easy to test if I am getting a signal. JF, I can rewire a ground easy enough, ill try it out
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Yes,...ground checks first.
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
