Torq Spec for 10mm cv's axle bolts.
Does anyone know the torq spec for the 10mm cv axle bolts?
60 ft lbs, with clean and dry threads.
Registered Abuser
60 Ft /LBS
re-torque after 200-400 Miles Read this thread Reconstructing Constant Velocity (CV) Joints
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
Thanks a bunch, crazy how much more torq the 10mm bolts take compared to the 8mm ones!
I just talked to Patrick Motorsports they looked up the factory torq requirement for the 10mm bolts and it said 44nm~ 34 ftlbs.
60ft lbs sounds to high to me... |
For what year car? My 73 has the 10 mm bolt, and the factory manual says 60 foot pounds.
John Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers |
Those don't sound like 10mm bolts, more like 8mm ones
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
The next harder steel bolt is grade 10.9, and the 10mm CV bolts are grade 12.9 hardness. You see those numbers on the head of German bolts. 12.9 bolts are rarely if ever plated and they are high carbon steel and dark grey in color. 60 - 63 ft lbs is what I've heard for the 10mm 12.9 hardness CV bolts and they should be clean with no oil on the threads. |
I think for the 85-89 Carrera 108mm axles, bc thats what I was ordering parts for...
