930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
electrical part of ignition switch?
do you have to r/r the mechanical part of the switch or can you flatrate this?top screw is a *****!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-03-2009, 11:45 AM
Hi
Targa Me's Avatar
What year?
What does Flatrate mean? Its not in my dictionary.
What are you trying to do?
Pictures?
Old 09-03-2009, 11:52 AM
h20cooled7's Avatar
78 911 sc
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-03-2009, 12:00 PM
h20cooled7's Avatar
flatrate\: when booktime says 3hrs but you knock out in 10 minutes!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-03-2009, 12:05 PM
h20cooled7's Avatar
Im just trying to replace the electrical portion w/out removing the entire assembly. disconnect harness remove 2 screws and put back together.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-03-2009, 12:06 PM
I changed mine out a month or so ago. the top screw is difficult but not impossible. I devised a tool out of a screw driver and a 1/4" socket... found myself in the drivers seat with my feet on the back glass.
Kevin
'79 Coupe
Old 09-03-2009, 12:09 PM
h20cooled7's Avatar
ok ill get creative
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-03-2009, 12:24 PM
It's do-able. I did it a few months ago, and I'm 73 and don't contort quite as well as I used to, though I'm still skinny enough to have done it by backing, upside-down, into the driver's footwell. That screw is a pain, and yes, you do have to get creative with it. Worse comes to worse, take out the driver's seat. A mini-Maglite that you can hold in your mouth--like making a night IFR approach when your instrument-panel lights have failed--helps.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 09-03-2009, 12:28 PM
h20cooled7's Avatar
ok you guys are giving me the confidence to do this! I am off ,I'll let you know how it turns out.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-03-2009, 01:04 PM
Nine9six's Avatar
Doing it the right way (removing the whole mechanism) is about a 1 hr job if you know what you're doing. And by knowing what you're doing, I mean you have done the job before, and you know what to expect.
The task is described in the 101 Porsche book, but it fails to state that there is a set screw that holds the steering lock mechanism into place, and its location. Once you finally remove your first key and lock mechanism, the next one is gravy.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 09-03-2009, 03:18 PM
Two tiny screws........
Watercooled7,
This job looks very simple but if you could remove these 2 screws under 2 hours for a first timer, you are gifted and creative. The space between the head of the screws and the dash is so tight that you need some special size screw driver/s to unscrew them. Once I got them out, I replaced them with allen type screws.
Removing the seat gives you more space to lie down and reach for the screws. With the seat inplace, you got to be a contortionist to successfully do the job well. Good luck and keep us posted.
Tony
Old 09-03-2009, 07:16 PM
On a related note, I got a pair of safety glasses with built in diode lights at sears for just this kind of job. Invaluable! I can't tell you how many maglites I nearly swallowed trying to get light where I needed it. $15 very well spent.
Argo
88 Targa
Old 09-03-2009, 11:11 PM
Won Won is offline
Won's Avatar
I have a tool that was perfect for this job. It includes a selection of interchangeable screwdriver bits, a short extension and a ratcheting wrench that goes over the bits/extension. It was just the right length to fit between the screw and the firewall. You must have those interchangeable bits somewhere in your toolbox, if not pick up a "universal screwdriver" type deal from walmart for $10 and just cut it to right length. Use a vise grip on it to break the screw loose, then the rest is easy. You don't really need to put the top screw back in after replacing the switch. I never did.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 09-04-2009, 12:29 AM
h20cooled7's Avatar
Job sucessfull, took about 10 to 15 minutes to remove. I did this job in a friends driveway and went the route that Won went with all the tools and bits I thought would cover the job. Sounds barbaric but the switch was coming apart so i just snapped the connector half off and had better access to the top screw. used some weatherstrip calk to hold top screw in and had the thing back together in 20 minutes. Thanks for all your help!
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 09-04-2009, 05:23 AM
