Question an unexpected find while swapping out my 911 valve covers. . .
[This relates to a 1979 911 SC, ~75K mi, no recent engine work.]
So, I was swapping out my valve covers for the turbo models
this weekend, and things were going well. After doing
the more accessible passenger side cover, I started the driver side.
Upon removing the driver side cover, I heard an unexpected clink of
an item hitting the valve cover. Looking on the ground, I found the
cylinder in the photo, one side threaded, the other side with an inner hex
pattern. The cylinder, coated with anti-seize compound, had been sitting
there a while, as there is a visible ring of the silver paste
in the square-ish hollow at the top rear of the cover. As I did not see
anything amiss in the valves or other parts behind the cover, I poked my
fingers into the upper hollow and extracted the broken threaded shaft
(stud?) also in the photos, also covered in anti-seize compound.
So, from an area separate from the valve activity area, I retrieved
two items that would appear to be important to keep an engine together.
I finished the driver side cover, filled it with oil, and started the engine, and it purred, but I have not driven the car otherwise.
Where might these parts be from? I had done nothing that day to precipitate
the breakage visible on the threaded shaft, and (obviously) have been driving with these stowaways for some time. I did actually notice the threaded shaft behind and above the covers before I started the cover removal, as I was unsure what a part looking like that would be doing in that area.
With parallels to surgeons who leave sponges or worse behind in their
patients, what do I need to investigate to ensure that these "spare" parts are just left over from past maintenance?
(P.S. I now surmise that this is a cylinder nut and a stud, from parts diagrams.)
Old 09-08-2009, 09:32 PM
a.k.a. G-man
Geronimo '74's Avatar
Broken cylinderhead stud, replace and check, or better yet, replace all the rest.
At 75k, it seems a little early, but that's what it is.
This means major work. (It is not likely to be left behind by a previous mechanic.) A good chance to perform any other necessary upgrades that have not been done yet.
Do a search on this forum on that subject, you will find tons of info. Buy Wayne's book on how to rebuild and modify 911 engines, it's a must have.
Good luck and happy wrenching.
Old 09-08-2009, 09:38 PM
muck-raker
kidrock's Avatar
+1, the dreaded Broken Cylinder Head Stud. Best to drop the motor and replace them all with the steel ones. good luck.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 09-08-2009, 09:52 PM
i'm just a cook
onlycafe's Avatar
at least you found a quarter too.
Old 09-08-2009, 10:04 PM
Checked out
McLovin's Avatar
LOL. Find 24,999 more of them, and problem solved!
Old 09-08-2009, 10:12 PM
Senior Advisor
James Brown's Avatar
arrrrgg, another broken head stud! good time to bone up on your engine skills, not a bad job but something you were not planning to do. Great info on here and in Wayne's book (a must have along with a Bentley manual) If you do all your own work, it's around $1000, Good luck!
08 Cayenne Turbo
Old 09-08-2009, 10:53 PM
Recreational User
porschenut's Avatar
Some people in other threads have commented that one or two broken studs are still okay, as long as they're not on the same cylinder, and replacement isn't usually necessary. I'm not certain this is true as I can't recall who has said it, but before you jump into an expensive repair it would be worth researching the situation to see if it's really necessary. Above all, have every one of the other studs checked.
Old 09-09-2009, 09:38 AM
Whenever we find a broken Dilavar head stud, we replace all of the other Dilavar ones as the others are just as likely to fail.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-09-2009, 10:58 AM
Somatic Negative Optimist
Gunter's Avatar
Which cylinder?
Exhaust row?
Check all other head studs.
Get a calibrated 3/8-drive torque wrench, get a LONG 10 mm Allen 3/8-drive socket, open the valve covers, check the torque on all head studs: 23-24 ft-lbs.
You may have to drain the oil from the sump or tilt the car on one side first and then do the other side.
With only 1 broken head stud, some people keep on driving; it's up to you.
Replacing the studs is highly recommended.
It's a major job.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-09-2009, 11:34 AM
chocolatelab's Avatar
i had 2 broken studs. I chose to get the studs fixed.
if its just one and everything else is fine i would be in no hurry
mileage isnt the issue for studs
its time/moisture that causes the issue.
1978 911sc Targa Sold 2001 996 Cab Sold
2006 Cayenne S Silver Wifes Car for sale
2011 Jeep Wrangler Silver for sale
2010 Toyota Prius Black for sale
2016 BMW 328D wagon
Old 09-09-2009, 12:33 PM
grateful user
don gilbert's Avatar
I didnt know mine was broken until it started making a popping noise, and here is the damage, Ended up getting a complete valve job, guides springs keepers and all new valves, plus the extra mach work to true up the heads Good luck on the studs. see my thread "need help on broken stud"
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 09-09-2009, 02:39 PM
jkh2cpu's Avatar
The affected head is going to work 'loose' and no longer provide a seal between the cylinder and cylinder head, which means that you will have an exhaust leak. Let it go long enough and it will destroy the surface between the head and cylinder and fry a valve / valve seat or two in the process. Get it fix sooner rather than later. If you hear it pop-pop-popping or hiss-hiss-hissing, take it off the road. You can fix it yourself if you have the tools, the time, and the mechanical aptitude.
John
Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers
Old 09-09-2009, 03:06 PM
KNS KNS is online now
The "pop-pop-popping" and "hiss-hiss-hissing", when would you hear these sounds? Under acceleration, idle, cruise...? Very noticeable or difficult to hear?
Kurt
Old 09-09-2009, 03:40 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
LOL I had 7 broken studs and the car ran fine. I didn't discover this until I decided to try to adjust thevalves myself.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-09-2009, 03:45 PM
scarceller's Avatar
Get them all fixed, in a prior 1975 2.7L I owned this issue resulted in leaks between the cyl and the head and damaged several heads beyond repair. The leak will literally melt material from the head once it gets worse. Also if bad enough it will cause air to also leak in during intake stroke and this un-metered air will lean the mixture and could result in detonation in that cyl, it was suspected that this was what finally destroyed my 2.7L.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 09-09-2009, 03:54 PM
jkh2cpu's Avatar
Popping and hissing? I've never heard that death knell myself, but the sage words came from Bruce Anderson. I think it hissing when cold and popping when hot, and at idle while listening near the motor. Don't confuse this popping with carb popping. Scarceller is telling you what I've read about the problem.
John
Old 09-09-2009, 04:45 PM
Thanks, everyone, for the input. I am not interested in risking more damage to other engine parts, as many of you warned about, so I am selling a major organ and going to the mechanic soon for stud replacement. I value Wayne's book but I do not have the garage space, tools, or equipment to even consider taking this on.
Old 09-10-2009, 08:17 PM
scarceller's Avatar
Wise choice, getting this fixed now is the best decision.
Sal
1964 356SC (SOLD)
Old 09-11-2009, 04:57 AM
jsmithcds's Avatar
Feel for ya man. Exact same thing happened to me. Good chioce to fix it up. Get ready for the "while our in there" expenses. I spent way to much on those....... Worth it in the end. If it's rubber replace it. Just keep in mind the 20 to 30% mark up on parts from your mechanic. Replace the easy stuff yourself to save some cash.
good luck
79sc Flared with a 3.2SS conversion 9.5:1 J&E's with 964 cams and M&K exhaust
Viper Green
He who laughs, lasts.
Old 09-11-2009, 05:38 AM
Gunter's Avatar
Thumbs up
Davo,
Make sure you go to someone who really knows these engines and issues.
During the stud replacement, insist on Steel studs, not Dilavar.
Replace all 24.
Do a valve job.
If the cams need to be reground, consider the 964-profile if you keep CIS, it has a slightly higher lift and is very compatible with the '79 FD and the larger intake runners. A 964-cam reground is only about $250.-? and you'll get an extra few horses.
Hopefully, you'll find Mahle (Nikasil) P/C's and not Kolbenschmidt (Alusil)
If the P/C's are Nikasil, just a very light hone is perfect with new rings.
If they're Alusil, re-ringing is sometimes not successful.
Old 09-11-2009, 07:00 AM
Tags
911sc , gasket , turbo valve covers
