Dog-faced pony soldier
Porsche-O-Phile's Avatar
Today's 911 discovery (tires)
225/50/16 tires won't quite fit under the front fenders of a '74 911. It's close, but they'll rub my a couple of mm. Admittedly this car has been lowered to Euro spec, but just figured I'd share. You're best using 205s in the front if you're considering it.
205/55/16 fits fine without rubbing. YMMV.
Black Cars Matter
Old 09-09-2009, 05:17 PM
Southern Class & Sass
Dixie's Avatar
Interesting. I wonder what's the difference between a '74 and an '88? 225/50/16 fit under my '88. It's below Euro height. The fenders have been rolled.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 09-09-2009, 05:22 PM
I'm using 225 60 16's on all corners on my 74, but I did have to raise the front back to stock height.
Old 09-09-2009, 05:23 PM
Yea, it's irritatingly close, but the tire does touch the fender lip by about 2mm. It's that close. Heck, if the tires were worn, I bet they'd fit, but they'll still rub when hitting an undulation/bump so I guess it doesn't matter.
I may eventually try 225/45/16 if I can find them. The width is fine.
Black Cars Matter
Old 09-09-2009, 05:35 PM
Porsche Enthusiast
With a fender roll and 951 8" fuchs, the 225 should fit on the front.
sold - 1978 911SC. Best car I have, and will ever own.
Current moving scraps of metal:
2010 Nissan Titan
2009 Buell Firebolt XB12R
Old 09-09-2009, 06:46 PM
Bill Verburg's Avatar
the way a tire fits has as much to do w/ the wheel, alignment and ride heaight as w/ the tire itself
Bill Verburg
Old 09-10-2009, 04:51 AM
Shaun @ Tru6's Avatar
Agreed, and a lot has to do with the tire. When I had my 84 Targa at 24.25 in the front, rolled fenders, I had 3 different tire makes on it, all 225/17's.
Michelin Pilots: very narrow tire, great predictable grip/release
BFG SO3s: wider tires, always felt a little greasy at the limit.
Kumho Victoracers: very wide, probably wider than a Pilot 235. Never hit their limit. these were awesome tires after warm-up.
Jeff, you may need to roll your fenders to get them in there. Post some pics.
Tru6 Restoration & Design
Old 09-10-2009, 05:07 AM
IROC's Avatar
Absolutely. I have 245/45-16s on 8x16s in the front with no rubbing.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-10-2009, 05:55 AM
IROC's Avatar
Here's how close 245s/275s are on my car:
No rubbing!!!
Mike
1976 Euro 911
Old 09-10-2009, 06:02 AM
Porsche Enthusiast
Holy crap, with standard SC/Carrera flares? What rims and offsets are you running?
2010 Nissan Titan
Old 09-10-2009, 08:33 AM
245 on 8s want as much lip room as can be had, the higher the ET the more lip room but the less room inboard. All the 225 -245 on 8s will rub on the inner wall, at the wide end of the tires the shock covers need to come off, they can be replaced w/ flexy silicon covers.
8 ET23.3 is going to be really tight at the lip even w/ 225 so you need lots of neg camber too.
8 ET31 is going to be really tight on the shock covers w/ the larger tires
using shorter tires of the same width adds additional room
235/45x17 on 8ET25 is very tight, 235/40 has plenty of room on the same wheel
Bill Verburg
Old 09-10-2009, 08:44 AM
Interesting... These are on BBS RS wheels, one set I have has the 205s, the other (built exactly the same) has the 225s. I'll post some pictures later. Maybe using different wheels would make a slight bit of difference but I figure it'd be pretty close either way...
Black Cars Matter
Old 09-10-2009, 09:08 AM
IROC's Avatar
The wheels are old HRE Fuchs replicas with custom offsets. The fronts rub the inner fender well at full lock, but then again so did the original 185/70-15s on 6x15s, so it's effectively no different than stock.
I still have the stock shock covers installed (and no rubbing there either). I've run a variety of tires (mostly R-compound stuff) and nothing has rubbed. Many people running this combo report rubbing on the oil lines, etc. in the rear but I haven't had any problems with that either.
Mike
1976 Euro 911
Old 09-10-2009, 09:11 AM
That's pretty unusual, to use 245/40x17 on 8 ET25 my shock covers had to come off, 235/45 barely clears
in back 275/40x17 on 9.5ET19 are centered in the available space, lips on the outside and trailing arm bolts and oil lines on the inside all needed work to clear.
I wouuldn't bother w/ any of the extreme sizes except on a dedicated race car.
Bill Verburg
Old 09-10-2009, 09:24 AM
IROC's Avatar
Yeah, I put this tire and wheel combo on over 12 years ago and didn't know any better at the time. It was the popular thing to do out west (POC) so I bought some wheels and tires and just put them on. They fit, so I never thought any more about it. I just assumed they fit on everyone's car.
Mike
1976 Euro 911
Old 09-10-2009, 09:55 AM
It takes rolled fenders and negative camber to run 225's up front.
How much neg camber are you running?
Each added deg of neg camber should get you about .2" of added room if my calc's are right.
Old 09-11-2009, 05:01 PM
