Tricks for installing rubber on S rocker deco?
O.K. give me your tricks for installing the rubber strip on the S rocker deco. I know I'll need lube and assume it slides in but it is a bear to do. Any tricks?
Old 09-12-2009, 07:57 AM
Silicon Spray - You'll be amazed at how easily it slips on. I was - it was so easy, I was even concerned that the strip would just fly off on its own when I drove down the road. This was after trying all sorts of grease and lubes and every swear word I could think of.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 09-12-2009, 08:00 AM
jkh2cpu's Avatar
I've always put the bottom in to rest on the lip, and then used a putty knife to pop the top in. Quick and no mess. Don't forget to screw it on to the car before putting on the rubber ;-) You might try my method off the car laying on a bench to see what I'm talking about. A body guy told me to try it that way.
John
Original Owner 1973 911T. Webers, SSI, SAW & Polybronze, Carrera chain tensioners, 'A' calipers
Old 09-12-2009, 08:35 AM
al lkosmal's Avatar
I installed the drivers side....no problem, but the passenger side was a beeeyatch. What Rex said...silicone spray is your friend.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 09-12-2009, 08:48 AM
I've tried the spray and it does help but boy does it take alot to get it in there. I didn't try to pop it in becuase I didn't think it would flex that much but maybe I'll give it a try. Thanks!
Old 09-12-2009, 08:54 AM
abit off center
cgarr's Avatar
I use a wire pull lube, it works great and easy to clean up. Home Depot should have it.
http://ideal.datacomtools.com/idealcatalog/wire-lubricant.htm
______________________
Craig
G2Performance
Old 09-12-2009, 09:04 AM
Dawn dish soap
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 09-12-2009, 10:58 AM
