1974 911 w/ 83 SC engine
Is there an easy way to tell what size Fuchs you have?
I have 16" Fuchs with 205's on the front and 225's on the back. What I don't know is the actual rim widths. I know Fuchs came in 6, 7, 8 and 9 inches. I know they aren't 9's. I asked the PO, and he doesn't even know. I haven't taken the wheels off yet to do any measuring, I was hoping I wouldn't have to. Is there any trick or easy way to look at them and say "That's a 7" or "That's an 8"? If it helps, they are on a normal 74 911. Thanks.
Old 09-12-2009, 03:53 PM
Bye, Bye.
Scooter's Avatar
If you post pics, I bet someone can tell you pretty easily.
Non 951 8's have a deeper dish to them, similar to 9's. 951 8's look more like 7's. 6's look even more different than 7's. (Looking at the face of the wheel that is).
Tires look different on each wheel as well, so if you post what size tire on each wheel pictured, that will help.
Edit: If you have a narrow bodied '74, then you should not have 911 8's or 9's.
Elvis has left the building.
Old 09-12-2009, 04:04 PM
Checked out
McLovin's Avatar
The size is stamped on the back.
Or, you could post a picture and I'll let you know.
But, even before you do that, I shall use my amazing ESP powers and tell you you have 16x6 on the front, and 16x7 on rear of your car.
2ndTARGA's Avatar
If the above don't work, any tire shop will have big plastic calipers that reach around the tire and read out the rim width. They're used to set up the tire balancer but can be used with the wheels still on the car. I doubt you'd have trouble getting a shop to help you out for free on this one.
Ron
1996 993 Coupe, Tiptronic, Polar Silver
1973 914 1.7 Marathon Blue Metallic - Sold
1977 911S Targa - Sahara Diamond Metallic - Sold
1975 911S Targa - Copper Brown Metallic - Sold
Old 09-15-2009, 04:25 PM
Or go to the For sale section and search for Fuchs wheels for sale (active or archived). Several threads will show the wheels as well as the marking on the back of the spoke.
Hope this helps,
Sherwood
Old 09-15-2009, 04:56 PM
WPOZZZ's Avatar
6s have a lip profile like this L. It has a 90*bend from the lip to the petals.
7s & 8s have a lip profile like this \_.
Old 09-15-2009, 05:41 PM
The trick is to take the wheel off. There are only 5 bolts and it is something you SHOULD do. With 11 posts I'd say you're new to the 911 community and likely the DIY aspect of 911 ownership. There is no time like now to start learning about your own car by doing. There are numbers on the inside of the wheel that will say 6J x 16 or 7J x 16 and the wheel part number. You might look at your brake pads, rotors etc, etc. Get a good jack and a jack pad for the square hole behind that black plastic cover in the rocker and get 'er done!
Tony G
2000 Boxster S
Old 09-15-2009, 05:52 PM
