I'm a loser, baby.
oregonmon's Avatar
Red face An intermittent clunk/knock from passenger side
Hey all,
My 79 911 developed a knock/clunk from the passenger side and here's the symptoms.
-passenger side
-thought it was from the front but not completely sure
-tempo of the clunk coordinates to the speed of car not rpms
-turning does not make it clunk
-on a drive to Lowes, when I left the house it was not doing it but on the way back home it was. ???
-seems to happen after driving a while
-can make it come on or louder if accelerating and will quiet down on decelleration
-took the front passenger wheel off because there seems to be a touch of play when wiggling the tire and wheel around (like the wheel isn't tightened down)
-tried to wiggle again by grabbing the brake disc but couldn't find the same play.
-tightened lug nuts
-stock suspension and all original as far as I know.
What am I looking at guys and girls?
Thanks.
1979 911 SC
Old 09-17-2009, 03:12 PM
WVU 911's Avatar
Send a message via AIM to WVU 911 Send a message via MSN to WVU 911
Check your front strut. It might be time to replace it
Old 09-17-2009, 03:54 PM
I'm a loser, baby.
oregonmon's Avatar
What would I do to check it?
1979 911 SC
Old 09-17-2009, 09:28 PM
IROC's Avatar
This may be on the right track. I chased a clunking sound for months only to finally remove my passenger's side rear shock (a Koni that was only a year or two old) and found that it was toast. I could easily compress it by hand. I replaced the shock and the clunk went away. I didn't associate the clunk the bad shock at first, but evidently that was the problem.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-18-2009, 04:24 AM
Possibly worn sway bar bushings. It took me a long time to find this on my car. The clunking occurred when cornering and when going over speed bumps. It stopped when I disconnected the drop links.
Steve B.
1972 911t
1999 328is
Old 09-18-2009, 04:44 AM
