MrScott's Avatar
I got part way into the valve adjustment yesterday, aiming to finish it today.
So far nothing seems out of whack:
- Axial play is similar on all rockers
- None can be depressed by hand
- The backside method rocks
I'll inspect all rockers to make sure they haven't wandered off their shafts but I suspect consistent axial play indicates they haven't.
On the driver's side half the exhaust cover nuts came off with the studs so before I did the passenger side I sprayed those nuts with PB blaster, all came off properly.
My exhaust gaskets were an unfamiliar green cardboard-like material.
Turning my fan didn't budge the cam pulley and the belt was already '5 shims' tight, thankfully the 6th shim did the trick but I've ordered a new belt to be safe.
I'll post some good closeup pics before the end of the day in case you all can spot something I can't.
I had an 'admit to your stupidity' moment when I went to remove the 2nd spark plug with the factory tool... thought a rubber boot on the plug itself was kind of odd when I removed the 1st, went to remove the 2nd, uh-oh! no boot! has it fallen?! I poked around with a mirror for a couple minutes before putting 2 and 2 together
1980 911SC
Last edited by MrScott; 09-20-2009 at 06:46 AM.. Reason: edited to include stupidity
Old 09-20-2009, 06:02 AM
timeless beauty
rcaradimos's Avatar
Valve clearance smaller for more HP?
I'll try to send you a pm w/ a video sound clip of my engine
I think your noise is excessive valve gap.
I couldn't upload the file.
It's amazing how quite a good valve adjustment will sound. Very quite cold, as the engine warms up you will get more sound from the tappets. Did you get a stethoscope? Cheap and a great way to monitor your valve adjustment.
Bob
87 targa
Old 09-20-2009, 09:44 AM
Hi,
Since you didn't find anything out of whack at the valves, I would take off your chain covers and have a look before re-starting. If you lost your tensioner, you could end up with an expensive mess!
Rutager
Rutager West
Old 09-20-2009, 12:01 PM
Senior Advisor
James Brown's Avatar
Originally Posted by rwest View Post
hi,
since you didn't find anything out of whack at the valves, i would take off your chain covers and have a look before re-starting. If you lost your tensioner, you could end up with an expensive mess!
Rutager
1+
08 Cayenne Turbo
Old 09-20-2009, 12:03 PM
MrScott's Avatar
UPDATE:
Number 5 intake valve (on the passenger side where the noise was coming from) was very loose. I'd been rocking the rockers before setting the gap to get an idea of how off they were -- rocked it a little, felt fine, rocked it harder, whoa, too loose.
Is this indicative of anything? I could have sworn I read that if you can rotate the valve the spring is broken -- can't find the thread though. I can rotate #5 valve but I can rotate the others I've tried as well...
I'm not ignoring the advice about the chain covers but I'd like to take one thing at a time.
I'm going to go through again and check all the gaps, rocker play and valve rotation.
EDIT:
Forgot to mention I realized my feeler gauge was metric. Did some math the convert the backside method:
Gap: .002857" = .07257mm
So GO is .07, NO GO is .08
I compared tolerances in millimeters with the two methods:
.0025" - .003" -> .0635mm - .0762mm -> .0091 (too thin) - .0036 (too thick)
.07mm - .08mm -> .0026 (too thin) - .0074 (too thick)
Seems the metric feeler's more accurate but getting the GO gauge in took some wiggling.
1980 911SC
Old 09-20-2009, 05:21 PM
Sounds like you found the problem. I'm suprised you can turn the valve. The clearance on these is very stable so something changed. Could be something stuck under the lip of the vavle holding it open? Could be a bent valve? If you just tighten it and it's staying open you will burn the valve.
-Andy
Old 09-20-2009, 06:51 PM
-Andy
Andy, That bent valve reminds me of the sound I had several years ago right after a complete rebuild. The machine shop screwed up but the shop that did the rebuild (SC Repair in Houston) made it right and took care of it. 3 years later still runs great and no leaks!
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 09-20-2009, 07:00 PM
MrScott's Avatar
Dug into it some more. Re: valve turning, might not be the valve I'm turning as the rest are just like it, so that seems fine.
I am getting a 'clanging' when I rock the #5 intake rocker that I don't get on the others. I'll upload a sound clip later. Also, I went through all the valves a 2nd time - a few had to be readjusted, so it could be my mistake, but #5 might have been more out of spec than the others.
Would a bent or stuck valve cause the noise in my first post? If not I figure I'll button it up and start it, if the noise is still there I'll have it towed to a mechanic -- if not I'll drive it .
Old 09-20-2009, 09:04 PM
Author of "101 Projects"
Wayne 962's Avatar
Before you take it to someone else - get a little bit more data. Run a compression check on the engine (I don't show how to do this in the 101 book, but it's in my Engine Rebuild book). There's also an article on the site, I believe (under "Time to Rebuild?").
Valve train noise is generally pretty easy to fix. I wouldn't panic yet. But yes, if there is something that "feels" different about #5, then most likely there is some type of problem with that valve.
It would be my guess that perhaps one of the two springs is broken, and it's not closing all the way. This would cause a leak, and would show up in a compression test. In general, you can't see the inner valve spring, so even if everything looks intact, there may be a problem inside.
-Wayne
Old 09-20-2009, 09:25 PM
MrScott's Avatar
Clip of #5 rocker as I rock it back and forth: sound clip
And for reference, the original clip I posted with the engine running: engine noise
They sound similar, so I think I've found my problem.
The 'clanging' happens when the rocker touches the cam, not the valve so does that rule out valve spring and valve trouble? Or must I be mistaken (it was getting late and I was getting tired and I don't have the car with me now.)
Wayne, thanks for the advice. I'll check that article.
And thanks again to all who replied.
EDIT: I just read the tech article, specifically the part about oily plugs -- from what I remember my 4, 5 and 6 plugs were oily indicating "valve guide or piston ring wear" ... Engine had leakdown under 6% cold on all cylinders when I got it a few months ago, maybe some catastrophic failure on that side. Man.
1980 911SC
Old 09-20-2009, 10:26 PM
Senior Advisor
I know it's hard to see the valve springs but can you use a mirror and a flashlight to check them. It should be quite easily to spot one, if any are broken. yeah, the backside method described in tech article is in fractions not metric. Double check the valve lash on # 5
08 Cayenne Turbo
Old 09-20-2009, 10:43 PM
MrScott's Avatar
I peeked around with a mirror but I didn't see any valve springs, broken or otherwise. Tried to search for a pic of what I should be looking for, no luck. I'll try again with more light.
Again though, I'm pretty sure the 'clanging' occurs on rocker to cam contact.
1980 911SC
Old 09-20-2009, 11:14 PM
Senior Advisor
that's good, look at the tech article there's pictures of the valve springs, just click on them to enlarge
08 Cayenne Turbo
Old 09-21-2009, 12:10 AM
pete3799's Avatar
MrScott,
Did you remove the plugs prior to your valve adjustment?
If so you may have dislodged some crud that may be holding a valve open, throwing
off your valve adustment.
Possibly why #5 was looser then the rest.
Pete
79 911SC RoW
Old 09-21-2009, 05:48 AM
MrScott's Avatar
I did. Just read that warning in the tech article.
Any suggestions on how to dislodge the crud?
1980 911SC
Old 09-21-2009, 05:55 AM
pete3799's Avatar
My Bentley doesn't cover crud removal, don't have Waynes book yet, maybe he has a crud removal chapter.
Hopefully someone else will enlighten us.
It's quite possible that #5 is just out of adjustment, as i had one on mine that was out more than the others when i bought it.
Quited things down considerable.
Hope all goes well.
Pete
79 911SC RoW
Old 09-21-2009, 06:34 AM
Btw MrScott, where in NY are you? Would be helpful for us to know.
Dom
1985 Black 911 Targa (Sold)
2007 Chev Malibu SS (wifey's car)
MrScott's Avatar
Certainly. I'm in Manhattan -- the car is in Queens.
Having to take a train to your garage slows the process significantly, especially when you forget your keys at home!!
1980 911SC
Old 09-21-2009, 06:44 AM
MrScott's Avatar
UPDATE:
With a mirror I peered into the #5 valve, tough to get my head in the right position with the engine lid in the way but I counted 3 maybe 4 coils which jibes w/the factory spring pelican lists. Top coil was tight against -- whatever it's supposed to be tight against -- valve hat?
I managed to get the suspect valve adjusted consistently; it seemed to me the swivel foot sometimes didn't seat well -- sticking my fingers down and fiddling with it gave consistent readings. This is my first valve adjustment so it could just be a lack of technique. Anyway, play feels normal and movement sounds normal now.
I ordered the gaskets, nuts, etc. from pelican. Going to pick up a compression gauge, button it up and test. Everything seems fine now but a valve going so out of adjustment so quickly doesn't make sense.
Makes sense, but if that's the case I'm no closer to finding the source of the original noise...
1980 911SC
Old 09-22-2009, 06:48 AM
Senior Advisor
fire that bad boy up!!!
08 Cayenne Turbo
Old 09-22-2009, 12:09 PM
