MrScott's Avatar
Worrying engine noise!
Gents,
Today when I started my car I heard a new noise from the engine: sound clip
The noise is coming from the passenger side. In the clip I move the mic from the passenger side to the drivers side at 9s, then back to the passenger side at 12s. My first (uneducated) guess is a collapsed chain tensioner? It's got the updated hydraulic tensioners.
After a short run I shut the car down. I'd rather not restart it until I'm sure I won't cause (further) damage. Thanks for any help!
Adriano
1980 911SC
Last edited by MrScott; 09-21-2009 at 05:42 AM.. Reason: converted sound clip to mp3
Old 09-18-2009, 01:14 PM
MrScott's Avatar
Might be relevant to add that my idle fluctuated on startup for 30 seconds or so before settling. This was the first time this happened since getting the car several months ago and coincidental with the new tapping noise.
EDIT: I took a chance and restarted the engine. Using the "screwdriver as stethescope" method I couldn't locate the source. It seems to be coming from further inside the engine than the valve covers though... not too sure. The frequency is proportional to RPM.
Old 09-18-2009, 04:25 PM
Oh Haha's Avatar
I can't get the file to play.
Pacific Blue
Wayne
Old 09-18-2009, 05:09 PM
MrScott's Avatar
Damn this iPhone. I will try to convert it when I get home. It's a loud "tap" "tap" "tap" coming only from the passenger side.
Old 09-18-2009, 05:12 PM
Senior Advisor
James Brown's Avatar
it sounds more like a valve clacking than a tensioner. try to use a long screwdriver placed on your ear and touch various places on the engine with the other end while the engine is running to locate the source of the noise, or use one of those fancy stethoscopes.
08 Cayenne Turbo
Old 09-18-2009, 05:20 PM
MBAtarga's Avatar
I was able to get the file to play with itunes, but couldn't discern what the problem might be. It's definitely noisy - and doesn't sound good.
Mark
'83 SC Targa - since 5/5/2001
Old 09-18-2009, 05:22 PM
timeless beauty
rcaradimos's Avatar
http://www.amazon.com/MECHANICS-STETHOSCOPE-ENGINE-DIAGNOSTIC-AUTO/dp/B002A1IQ58
I would try this method, under 20$ @ any auto part store
Bob
87 targa
Old 09-18-2009, 05:24 PM
MrScott's Avatar
I managed to convert it to mp3: sound clip
1980 911SC
Old 09-18-2009, 05:27 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Sounds like a noisy rocker arm, pull the covers and check for a backed off tensioner.
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 09-18-2009, 05:34 PM
bourgeois911's Avatar
Broken valve spring? I only mention it because I had one let go earlier this summer and it sounded similar.
Tom
79 911 SC
MrScott's Avatar
Safe to assume I probably shouldn't drive home?
Should I even start the engine again?
I will consult the bentley/101 projects re: rocker and valve springs, thanks all.
1980 911SC
Old 09-18-2009, 05:40 PM
Oh Haha's Avatar
eric
+1
Start at the rocker arms. When you find the loose one check the valve spring for breakage. If you can isolate the ticking to DS or PS you may only need to remove one valve cover to find the culprit.
I would check all of the rocker arms and adjust as needed.
Pacific Blue
Wayne
Old 09-18-2009, 05:54 PM
Free minder
Aurel's Avatar
When was the last time you adjusted the valves?
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 09-18-2009, 06:38 PM
MrScott's Avatar
I haven't yet. I realize that should have been first on my to-do list. I've had the car for a couple thousand miles now.
Old 09-18-2009, 06:40 PM
MrScott's Avatar
I just read through the 101 projects valve adjust procedure -- by 'tensioner' you mean the retaining nut? Relative novice here so pardon my ignorance. And if it's just the tensioner and not a broken valve spring will this valve adjust set me straight?
1980 911SC
Old 09-18-2009, 10:30 PM
Oh Haha's Avatar
That's correct, Mr. Scott.
The big question is why did the nut "back off", if it did. If a valve spring broke, there is no tension on the rocker arm, causing it to be loose.
I'm sure a Pelican is close and maybe could help you with this.EDIT: Just saw that you are in MY.
If you don't know what you are looking for, it will be hard to find. The good news is that it isn't catstrophic.
Pacific Blue
Wayne
Old 09-19-2009, 05:26 AM
MrScott's Avatar
That IS good news, thanks.
I searched a bunch and from what I gather I shouldn't be able to compress the spring with hand pressure on the rocker.
It's not getting buttoned up until next week anyway since I need to order gaskets, nuts, etc. so I figure I'll go through the valve adjust procedure and if one rocker doesn't feel like the other I'll dig some more.
Solid?
1980 911SC
Old 09-19-2009, 05:57 AM
Oh Haha's Avatar
Solid!!
Pacific Blue
Wayne
Old 09-19-2009, 06:03 AM
MrScott's Avatar
Seems it would help to isolate the location with a stethoscope -- but is it safe to run the engine?
And thanks for the early morning help, I'm headed over to the parts store now for a 24mm socket.
1980 911SC
Old 09-19-2009, 06:15 AM
Almost Banned Once
sc_rufctr's Avatar
Just listened to the noise...
It sounds like a broken valve spring to me.
But I can't be 100% sure because it's a recording and it's not in a 3d space.
Can you get to an experienced Porsche mechanic? I hate to be a drag but that may be the best solution.
The experienced Porsche mechanic should be able to tell exactly what it is...
- Peter
Old 09-19-2009, 06:17 AM
