My other ride is a C-130J
caliper ID and upgrade
I was wondering how to identify what type of stock calipers came with my 1975 S US spec 911.
l would like to replace these calipers with a set from a 1983 SC. Is this a straight swap? Any mods needed to the brake system?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Actually, they are the same setup. You would need to upgrade to a 84-89 setup to see any difference. IMO, the difference would be small.
What's wrong with your current setup? Unless you are tracking the car, the stock system, when working properly, is more than adequate. I did a quick search and found some threads for you to read. http://forums.pelicanparts.com/search.php?searchid=4382328 here's another one that discusses brakes-http://forums.pelicanparts.com/showthread.php?t=499669
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
If the stock Ms are still on the front then to use the later '83 A calipers you will also need later struts w/ 3.5" caliper mounting ears. The ones form an '83 would workfine. as long as you are doing that, I'd recommend Bilstein struts w/ 3.5" ears and w/ hd inserts. as an additional upgrade use '84 -89 wide A calipers and rotors, they are 4mm thicket that the '83s No other mods to the brakes are needed.
Thanks for the replies. Definately not tracking this garage queen. The '75 sat in a garage for 18 years and I'm merely concerned about safety.
I replaced the original flexible brake lines with steel braided ones bought here. (GREAT service Wayne, thanks for the Jelly Beans ) and know the '83 calipers would be in better overall shape you know seal wise. (I recovered them from my '83 -RIP)
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 09-19-2009 at 08:33 AM.. |
