donnmaddy
Need help AC problem
This last Spring my AC was low on refrigerant so I tried to added more refrigerant to the system but the system wouldn't not accept any of the refrigerant I tried to add. I flushed all lines, the condenser, evaperator. I installed a new expansion valve, a new Denso compressor, a new dryer and ester oil. I then started adding 134a. refrigerant, the temperature went down to about 55 degrees, the low side was about +25 and the high side was about 125 the system again would not accept any more refrigerant and temperature started to rise to about 70 degrees at the vent. Now I am back square one. I sure need some help.
You need to properly evacuate the system.
'87 Carrera - 2400 lbs of Track Beast!! '88 Carrera Cab - Too nice for the track. '85 Targa - Salvage title that was not caught! |
Member 911 Anonymous
You can actually rent a vacumm at Autozone or Kragen, for FREE.
The vacumm must hold for at least 30 minutes at negative 30 atmosphere, to insure there is no leaks and proper evacuation.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thread Tools | |
Rate This Thread | |
