New and Old lids. Not interchangeable.
Work to Live, don't live to work... |
George |
Schleprock
BTW just to add more hardware options, I recently ran across this Timmons Billet site.
Porsche You can get some fancy brushed aluminum cover plates from them. A friend lives in Wichita and says Timmons is legit. Been in the racing business for many years and still around.
Kevin L '86 Carrera "Larry" |
Thanks merv
Merv Porsche 2003 996 Turbo Porsche 1988 911 Carrera |
Vintage Motorsport
ITG is a good choice.
Richard Newton |
Thanks Richard. I will see if they have the oval version for the early filters as above.
Cheers, Merv
PMB Performance
Has anyone successfully used a stock 70's style filter housing with PMO's?
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
back about 20 years ago, I used to run a 4 barrel paper filter element that I reshaped to fit the weber bases.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
1984-911 M491
PMO ITB's on '84 3.2 using backdated air box:
1984-911 TLC......SOLD |
Trog - very nice! I have plans for that in my future. I want to go to EFI ITB's, but use them with the old airbox. Easy to do with the PMO ITB's.
PMB Performance
Thanks Brooke!
Can the existing bases be modified on a drill press vs welding? I'm at Parade so I can't get my eyes on this and I'm looking for options for my mechanic.
Eric,
AFAIK, the bases for Webers (maybe Solexes too) have the same screw hole pattern to the carb top (same as the velocity stack mounts). However, the lower "bathtub" portion of the AF housings are different and must be used with the correct upper section. The shapes are slightly different with clips in different locations. IOW, top and bottom portions must be compatible. |
Bird. It's the word...
The Fabspeed airbox cover (painted satin black) is a nicer/quieter alternative than just cutting the snorkel too...
John Forcier Current: 68L 2.0 Hotrod - build underway |
Frankly I do not know if you can just cut a few more holes in the bottom of the weber "bath tubs" to get them to bolt up to PMO's. I didn't try that.
Hmmmm. I'll have to give that a try to see how it compares to my snorklectomy.
