Free minder
Aurel's Avatar
Help diagnose strange throttle sputtering noise
I`ve got this annoying little noise at mid throttle that is coming from the CIS area on the engine. I think sputtering is the correct term to describe it. It sounds like shaking a crankbait with a little bead inside, for those who fish...But this is not detonation, I run 93 octane, my advance is at factory specs and it definitely comes from the CIS/throttle area. I have also noticed my gas mileage has decreased, but power feels about the same. Something is going on in there. What could it be?
I adjutsed the valves and changed the oil last week-end, but I do not see how this could be related. Other difference would be that the weather is cooler now.
Any ideas?
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 10-13-2009, 06:36 AM
docrodg's Avatar
Are you sure the valve adjust is correct? Could be a little tight on a valve causing some reversion. That would explain the lower gas mileage too.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 10-13-2009, 06:44 AM
Free minder
Aurel's Avatar
I`ve never heard what reversion sounds like, but you may be right. I will look into that possibility.
Old 10-13-2009, 06:52 AM
docrodg's Avatar
Reversion (mixture flowing back into the intake) can rattle, or other strange noises. It all depends on the intake system and amount of reversion. Seems as the best guess tho considering the recent work and symptoms. Also may want to check the CIS and make sure everything is in ordnung. Maybe a loose bolt or something.
1968 911S "Leona"
Old 10-13-2009, 06:57 AM
Free minder
Aurel's Avatar
That means one of my intake valves would be too tight. Easy to check, no need to drain the oil. The noise could be the air metering plate fluttering around maybe?
Old 10-13-2009, 07:05 AM
docrodg's Avatar
Yep on both counts. Intake valve is off or maybe a loose ??? in the CIS. Air metering plates make some weird noises, had a VW with CIS that howled and also did a lip-flapping noise (like imitating a horse) due to a funky air plate.
1968 911S "Leona"
Old 10-13-2009, 07:44 AM
Free minder
Aurel's Avatar
Update: I readjusted my intake valves, the engine runs fine, but...the noise is still there! It is a screeching noise, which seems external to the engine. Now, I noticed my trip odometer is dead, so I am wondering: could it be the noise of cable teeth grinding in the gearbox? Has anyone experienced this kind of noise associated with odometer failure on a 78Sc?
Old 10-19-2009, 08:33 PM
