torresmd's Avatar
Problem installing Tarett Sway bar
I am in the process of installing a rear Tarett sway bar in my 1986 Turbo. I fit one side, no problems, but when I try to mount the passenger side, it stops about 1/4 to 1/2 in shy of the stock mount. I realize that the bar is hitting the tranny mount. Has anyone had this issue? Am I doing something wrong?
1998 993 C2S Guards Red/Black
1990 964 C2 RWB project car
2016 GT3RS White Daily driver
2018 Lamborghini Performante Gegio Telesto
Old 11-04-2009, 05:10 PM
Chuck Moreland's Avatar
On the turbo you typically have to space down the bearing blocks for clearance. Use some flat washers, both sides.
Chuck Moreland - elephantracing.com - vonnen.com
Old 11-04-2009, 05:14 PM
torresmd's Avatar
Thanks Chuck!! I will do that.
Old 11-04-2009, 05:16 PM
