CIS fuel filter. how often do you change it
the title says it all.
i have at least 30k miles on my filter. i checked my tank not long ago and it was very clean. what symptoms would you expect from a dirty filter? high RPM bad performance? bad starting? or just bad all around performance i have another one ready to go on, just curious, actually a slow day at work and looking for something to talk about.
Almost Banned Once
I change mine bi annually and I drive my car about 10,000kms a year.
I know that's way to often but my 911 is one of the few luxuries I allow in my life. I've never had any issues with my fuel system so I can't comment on the symptoms of a dirty filter. What does the service manual say? As an example according to the Bentley, my VW Golf VR6 filter should be changed every 50,000kms. (This car also gets a new filter bi annually) Hope that helps.
- Peter |
grateful user
i have a 75, and i like to change it at least once a year, but i only drive it around 5-6 k a year. If your 77 is like my 75 the pump is in the rear, and there is enough room to put a filter in front of the pump. Gives me peace of mind. Napa has a short clear plastic one with 2 10 mm fittings, works great, very easy to change.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
pump is up front. i guess i am long over due
CIS needs clean fuel and a filter is a cheap insurance! I change mine once a year and I might drive up to 5K if I am lucky!
Bob 73.5T |
Somatic Negative Optimist
Depends somewhat on size.
SC's have big and small depending on what year. I like the bigger one and configured the lines and fittings for it. Mark it with date and Mileage for referrence.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
unless its a stock 74
Try and find those original OEM fuel filters for a 73 1/2 and 74 CIS . . . $$$$$$ if you can find them.
Fortunately my car came with 3 extra filters per original owner records, over 22K miles and still flowing fine.
M-74 |
