That would be worrisome given that they are cast.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Undocumented User
The new real deal Fuchsfelge seem pretty light.
Front: 17x7 ET55 | 16.5lbs | $698 Rear: 17x8 ET52 | 17lbs | $738 Rear: 17x9 ET55 | 17.5lbs | $778 |
I just took delivery on a pair of Euromeister 16x9. Each box weighed 23lbs. There was a thin foam sheet and piece of cardboard. I doubt packing materials weighed more than 1.5lbs.
1982 911 Targa, 3.0L ROW with Webers |
So they are substantially heavier than real Fuchs.
What's substantially heavier?
My 16X8 Euromeisters were only a couple pounds heavier than my 16X7 Fuchs.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
A couple pounds (~10%) a rim? That's substantial for rolling weight. Half that would be troublesome. A quarter of that would be pesky.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
With a good wheel you get to pick two of the following traits: Light Strong Cheap With a bad wheel you get one or none. Euromeisters certainly check the cheap box, and might check the strong box. They weigh enough for cast wheels to be somewhat promising in that regard, but there certainly isn't any definitive information.
PBO
patz, a "dead give away" of what? Read "twistoffat" above, if "he" is correct it's relevant. As I stated above, I've had two individuals that deal in Porsche parts deem them "original", I'm just wanting to NOT misrepresent the wheels since my intent is to sell them. Jim
I just called automotion where I got my 17" wheels and a 16x8 is 20 pounds right from the horses mouth.
Jim. I have no idea if your wheels are genuine Fuchs. However, I find it disturbing that you do not include a picture of the cast in mark that looks like a fox head (which is their symbol). Typically, high end manufacturers include trademark Item like that to help detect fakes.
If it was me, I would post at the Early 911S Registry and give them a chance to tear you apart. There is a ton of tribal knowledge over there on all things early 911. Last edited by HarryD; 08-26-2015 at 05:47 PM.. |
Pelican claims they are 22 pounds.
I can weigh a 16x9 Euromeister tonight on my bathroom scale and report back. The wheels I have, have not been balanced or mounted so no valve stems or wheel weights.
Functionista
I also doubt there would've been a market back then for fake 4.5s. Certainly not low weight forgings. |
Fuchs 15 x 4.5 part number 901.361.012.01 pair 5.5 x 15 fuchs dated 3/68 Note the stampings.
Its the date codes for concurs etc. Look at the value of a 76 930 for example. Most owners want date code matching 16x8s when they restore them.
That makes sense for the ones people haven't botched with chrome/polish/whatever, but prices in general are nutty.
Functionista
Eight worn lug nuts says those 4.5s are real!
Jim, weigh one of them. |
The forged wheel is much thinner in the spoke areas. The cast wheels are very thick when you look at the back of the spokes. The read from the German is mostly spot on except the 4.5X15 replicas have been out for many years. From the front very close but the insides are very thick and machined rather than forged looking angles. And Fuchs can still make the late (flat) 15s and 16s if enough are back ordered. But early (deep-901 style) wheels not so much......more of a liability problem I was told. HTH H |
The wheels in your photographs are Fuchs. The markings are consistent with 4.5X15 replacement wheels available through the parts dept. They were made well into 1970....maybe later but the latest that I have on file is 7/70. BTW, if they are for sale let me know. HTH H Last edited by HARVEYWEIDMAN; 08-26-2015 at 08:23 PM.. |
Harvey:
Thank you for "weighing in". I am surprised by the lack of the Fuchs Logo. It would have made me suspicious.
