Alternative to Innovate LM1?
I have Innovate LM1 and far too often get the ERROR 4 - PUMP OPEN message.
After many times removing/replacing sensor plug into read out box the unit functions properly - untill the next time I want to use it. Sent the unit back to Innovate and they "fixed it" Same problem exists. So - Does anyone have exprerience/suggestion of other manufacturer's AFR reader? Appreciate any input EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
I hope someone has an alternative as well, the LM1 is a terrible product. They have a good warranty, but 3 O2 sensors in a year is excessive. All of the sudden I would get a zero volt reading, solution was a new sensor three times, then a new controller twice. After that I sold it.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Funny, I have nothing but good things to say about mine. It was a godsend as far as tuning my oddball MFI 3.0L application.
Where was your O2 sensor mounted? They are very sensitive to over heating, so if you used the sensor bung on the SSI's, that could have been the cause of your trouble. It will overheat even with the heat sink. The only place I've been able to mount mine to get any kind of life out of it has been in the tail pipe, using their clamp made for the purpose.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Been very reliable for me for the past 4 years.
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
AEM UEGO Controller. . . available at NAPA
Parts #s AEM30-4100 Six in one Gauge type UEGO controller AEM30-2710 10 channel Peak & Hold Injector driver AEM30-2204 K type Thermocoupler Amplafier AEM30-2300 Single channel UEGO Controller AEM30-2301 DUal Channel UEGO controller Catalogue says prices start at $364.00
theres nothing like the rear end squatdown of a turbo |
