No ignition after rain
I live in rainy country (Victoria, BC, kind of like Seattle). After a recent rain, the 1971 911T won't start. Starter works, fuel pumps whirs, dash lights, but seemingly not one bit of spark. The engine gets so wet through the rear deck lid grille it just seems like a ridiculous idea to try to drive this, but... it's my new (and only) car...
What is the sort of "working backward" procedure to find where the electricity flow is stopping?
This car has a lot of electronics on the left side of the engine compartment I don't know enough about...
Thanks.
Old 10-30-2009, 01:32 PM
jtfreels's Avatar
It might be a simple thing, check inside the distributor cap and see how wet that is, moisture will condense inside the cap. If you haven't checked that already.
Jay
2002 Boxster Speed Yellow
Old 10-30-2009, 02:00 PM
Detached Member
Hugh R's Avatar
Spray WD-40 on all the ignition wires, and coil wires and dry the inside of the cap.
Hugh
Old 10-30-2009, 02:23 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
check inside the distributor cap. happened to me once that the cap was not on exactly right and water could get in there.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 10-30-2009, 03:59 PM
muck-raker
kidrock's Avatar
yep, probably wet inside the dizzy cap. Check yer points, too.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 10-30-2009, 07:46 PM
19 years and 17k posts...
azasadny's Avatar
Replace the distributor cap, it's probably got a crack in it (mine did).
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-31-2009, 05:30 AM
pmajka's Avatar
every one calls out the dizzy.
my 20 yr old Ignition wires were dry rotted and cracked (just enough to let water in)
How old are your wires?
WD is a temporary fix.
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 11-02-2009, 08:44 AM
Ignition cap and cables, the Achilles' heel of all 911s that have them.
Old 11-03-2009, 12:44 AM
The distributor cap got wet on mine and i had to get my car towed to a shop and spent all day checking spark, fuel pressure, compression and a few minor things, only to realize that taking off to screws and wiping down the distributor got the car started......it was a crap day
Old 11-03-2009, 05:31 AM
