racer_X's Avatar
How far can I advance the timing?
I just add the Ignitor Electronic Ignition to my completely stock 2.7. I have it set to the stock settings and it idles dead smooth now at 950 rpm. However- it doesn't seem as "crisp" under heavy throttle- probably my imagination.
Can I bump up the timing and if so how much? I'm near the great lakes and enjoy 93 octane.
Old 10-31-2009, 06:06 AM
I assume you reset the timing after installing the Pertronix. The total timing should be about 38 degrees at the most - assuming you are using high octane gas. I usually set mine around 36 degrees just to be safe.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 10-31-2009, 06:21 AM
racer_X's Avatar
38 max- got it,
Thank you Mr. Middie!
Old 10-31-2009, 08:28 AM
set up a signature with the model year
anyway what year distributor
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-31-2009, 10:30 PM
Bland
unclebilly's Avatar
UNTIL IT PINGS! under full load acceleration.
Old 11-01-2009, 07:58 AM
T77911S's Avatar
you may be hurting your performance if you advance the timing too much. the ONLY true way to set set the timing for optimal performance is on a dyno.
as you advance the timing, the piston is still building compression, so when it fires, the ignition of the fuel is pushing down on the piston as it is still trying to go up, reducing HP.
here is a good article on detonation, pre ignition and timing.
i could not get to the site. i am my work computer but here is the link. i hope it works
Engine Basics: Detonation and Pre-Ignition - ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-03-2009, 05:30 AM
