AutoBahned
RWebb's Avatar
Hidden Rust Areas
http://www.early911sregistry.org/forum/showthread.php?t=30620
everyone should view this boresope video
the real question is how you get the debris out and fix the nasty areas...
Old 11-01-2009, 11:06 AM
Duckworth's Avatar
Excellent video...
Glad you posted it.
____________
'82 911 - sold
'80 928
'77 Spitfire
Old 11-01-2009, 08:37 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
FWIW,
The aviation world has been battling corrosion since planes began being made from metal instead of wood(termites). ACF-50, Corrosion X, and a few more are around. If the car is stored anywhere but the Mojave desert, corrosion is gonna be an issue. I think AAA classifies an area within 200 miles of a large body of water a hostile environment.
eric
P.S. A few possibilities:
http://www.aircraftspruce.com/catalog/appages/corrosionx.php
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 11-02-2009, 08:10 AM
Duckworth's Avatar
...the real question is how you get the debris out and fix the nasty areas...
With the ads of 30 - 40 yr old porsches offered for sale that sit in less than ideal climates...with little protection - I'm curious if a borescope could ever be used before signing a check over to the p.o. ?
I'm keen on older cars - but unfortunately have come within a heartbeat of being swayed on a few occasions by a fondness for nice appearing rustbuckets - unwittingly.
There are threads we've all seen where someone's luck fell short - and then much help is offered for them to learn cutting welding and fabbing skills etc.
Worse...there are literally dozens of hidden corrosion areas on these cars if i'm not mistaken.
_____________
'82 911 - sold
'77 Spitfire
'80 928
Old 11-08-2009, 07:19 PM
"farking Porsche hero"
Rich Lambert's Avatar
No one's going to do a colonoscopy joke? Okay, two polyps walk into a bar and....
I found similar carnage when I replaced the suspension pan on my '66. The only outward signs of trouble were some tiny pin holes in the bottom of the pan outboard of the t-bar mounts. I mean, these were tiny tiny pin holes that you could barely see. They appeared only after some pounding in that area during a suspension refresh and the only reason I noticed anything was amiss were the tiny trails of rust dust falling out of the holes. It's scary, what's lurking a mm out of sight.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 11-08-2009, 09:04 PM
Duckworth's Avatar
Just the pan....and everything else is solid ? You're fortunate...sounds like the rest of the car is clean.
This is worth a look :
Part it or save it - what would you do?
___________
'82 911 - sold
'80 928
'77 Spitfire
Old 11-09-2009, 03:45 PM
