"O"man(are we in trouble)
Interesting tail on the car. That is a turbo rubber lip w/ early Carrera tail piece, usually it's seen with the flat rubber, what I believe is called the "tea tray".
Hello, I know the tail was probably added as I can see a slight variation in paint color. Glad to know its unique! Late last night I did the spark test in the dark. I did not see any sparks arching anywhere. I also had a buddy crank the engine as I pulled each plug boot off using an extra spark plug. Grounding the plug to the engine all 6 had spark. I am going to remove the injectors this afternoon. Ill post to let you all know what happened. Thanks again for the help!!!
Got the injectors cleaned. WD40 and blew them out with an air hose. I'll prime them and go for a drive........
Well that didn't make much of a difference. However the large adj. screw on the intake was screwed all the way in....I screwed it out some and now the car at least runs a little better.
