Bland
unclebilly's Avatar
Autodesk Inventor - Interesting Photo
I am removing Inventor 2009 from my computer to clear up some space. Autodesk has pictures that flash through during the install / uninstall.
This one is pretty interesting. especially since I doubt that Porsche uses Inventor...
Looks like 993 engine assembly?
Old 11-10-2009, 07:34 AM
racer_X's Avatar
I thought Porsche engineers used Pro E in the 90s. I know the designers used CDRS to do the surfaces for the Boxster.
Not sure what they are using now......
John
1977 911S
Old 11-10-2009, 10:04 AM
CATIA is pretty much standard now. Mercedes, Honda, BMW, VW, GM (I think), Chrysler. etc.
I bet they use that.
Old 11-10-2009, 12:19 PM
And the Guggenheim Bilbao museum and the Denver Art Museum...
Old 11-10-2009, 12:51 PM
GM is actually using UGS. I think that there are at least 1-2 other Auto companies that use them as well, like Fiat.
Old 11-10-2009, 12:59 PM
Hi guys,
Most automotive companies uses some kind of Autodesk software, even though other CAD vendors are used for designing the actual cars. Autodesk Inventor is often used for designing tools, machines, factory layouts, automation and so on.
The automotive industry is maybe the most competitive industry of them all, which make sure they don't use a super expensive solution for designing stuff an ordinary AutoCAD could do for a fraction of the cost.
Most car manufacturers use Autodesk Alias Automotive for conceptual design and/or surface modeling, and maybe Porsche is one of them?
I'm working for Autodesk, so I'm biosed....
Unfortunately not in Germany, so I can't sneek in to a Porsche factory.
Regards,
Johan
-14 Cayenne S Diesel, DD
-92 964 C2 convertible, RS -92 look and feel😃
-73 T US MFI Targa, restored
-70 T Coupé Hot Rod, painted waiting for assembly
-72 T Coupé, US numbers matching under restoration
Old 11-10-2009, 01:52 PM
DW SD's Avatar
I think those are 964 engines. 964 had aluminum valve covers. I think 993 has plastic.
Maybe I'm wrong.
Cool picture, nonetheless.
Doug
1971 RSR - interpretation
Old 11-10-2009, 03:21 PM
Originally Posted by jsoderbe View Post
Most car manufacturers use Autodesk Alias Automotive for conceptual design and/or surface modeling...
Regards,
Johan
No, they don't use Autodesk. Maybe for plant layout, maybe for concepts. Body and structure for production are almost all CATIA now. Tcar is correct. G.M. is still UGS.
Old 11-10-2009, 04:05 PM
Transplanted User
mkossler's Avatar
Hi guys,
Nope.
They use CATIA, UG (Really, NX) and IDEAS. Inventor is not in the same class, sorry - not to say it's a bad MCAD tool but it plays in the Solidworks / SolidEdge / Microstation (and now, Pro/E Wildfire) arena.
EDIT:
Reading your post again, I'll take it back. It is not uncommon to use Autodesk products for ancillary designs. I sure as hell wouldn't recommend doing tooling in it especially given how important tooling is in the high-production automotive environment, unless you don't want to do the design in-context. Outside of that, derivative drawings would make reasonable sense.
Matty K. - 82 SC Targa - SCWDP member #0052
"Racing - the sport that requires more than one ball to participate"
Old 11-10-2009, 04:23 PM
Bland
unclebilly's Avatar
Hi guys,
Regards,
Johan
Good - now I know who to email / pm every time this overpriced $h!t crashes on me...
Old 11-10-2009, 05:27 PM
Bland
unclebilly's Avatar
Maybe I'm wrong.
Doug
I dunno about that - I'm pretty sure my 964 doesn't have plastic (or black) timing chain covers.
Old 11-10-2009, 05:28 PM
PRO Motorsports
Tyson Schmidt's Avatar
Definitely 964. Look at the plug wire routing.
Those aren't plastic chain housings. They never used plastic. That is what the magnesium looked like when it was new. It's a coating.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 11-10-2009, 05:41 PM
Easily Confused
dtxscott's Avatar
The 993 has black plastic valve covers. So I'm betting they are 964 variants.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 11-10-2009, 06:00 PM
racer_X's Avatar
Yeah- AutoDesk bought Alias a couple of years ago, which has been the standard for all Industrial Designers in the US to do the car bodies for the last 15 years. Chrysler engineers used Catia, GM engineers used UG and Ford was ProE.
I was at the Detroit auto show in the 90s when Porsche introduced the Boxster. I had dinner with the lead industrial designer. They were using Pro Designer (CDRS) to do the CAD for the bodies and interiors. They switched to ICEM at some point, then to Ideas I think.
John
1977 911S
Old 11-10-2009, 07:24 PM
Transplanted User
mkossler's Avatar
I appreciate your efforts here to do some categorizing, but just a couple tweaks .
Alias Wavefront is a styling tool, not a CAD tool. Its cool factor is off the charts, but it's really meant to come up with some pleasing geometry and rendering, the geometry of which can be imported as surfaces / skins into selected CAD tools to do the real work.
Ford was IDEAS. It went to CATIA a few years ago for selected models. It never used Pro Engineer as a primary design tool. You have to keep in mind that all complex product manufacturers will be heavily influenced by their data management software when they pick their CAD tool(s). Ford has never ever been a Windchill house.
ICEM, better known as ICEM Surf, is a lightweight rendering / visulization tool that also is not CAD. ICEM was bought by Dassault Systemes, the owner of CATIA, and is now marketed as 3DVIA. They should have bought Right Hemisphere. One guy's opinion.
Old 11-10-2009, 07:37 PM
Yea, what he said. ^^^^
Dassault seems to be taking over...
Old 11-10-2009, 07:51 PM
Hi all,
Unfortunately you guys might be right about CATIA/Dassault on Automotive customers, I don't argue with that. However, outside Automotive there is another play field.
Porsche is an Autodesk CAD customer and an Alias user. As said before, Alias isn't a CAD system, it's a concept design/Surface modelling tool. I don't think they where a Alias user in the 90ies, since we bought Alias just a couple of years ago. Before that I believe it was GM owned.
Besides that, thanks for great information! This message board keeps surprising me in a positive way; now I know there are a lot of CAD experts here too....
Thanks,
Johan
Old 11-11-2009, 01:44 AM
