Drive it like u stole it.
jonesb930's Avatar
Wheel Lock Key Missing!!! Help please!
So I had today off and figured I would mount the new wheels I just received. The back was not a problem. The front however still had a wheel lock on it and I do not have the key! It is not your typical lock either. It is a lock from a Company called RND Ltd. in Mountain View, CA. I have the card that came with the locks.
Here is the info from the card.
ALLOY WHEEL LOCK SET
FIVE PIN STYLE
KEY: 1S
Does anyone have these? They look like the base of a lug nut (the ball part) with five holes in them. The key had 5 steel pins that would seat into the holes and allow them to be removed. I believe I purchased them from Performance products about 15 or more years ago.
Bill
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 11-11-2009, 09:19 AM
Wilywilly's Avatar
A punch, a chisel, needle nose pliers, small hammer and about 30 seconds of your time and they can be removed. You will need a new lugnut though.
Bill B.
63 Little B Coupe
67 SWB 3.63 Hotrod
08 Cayenne S
65 F100
Old 11-11-2009, 09:27 AM
a 3/4" deep hole saw on your drill motor. does not damage the wheel unless you keep drilling after the piece pops loose. never had any luck with the punch method. if they were that easy, all the thieves would have punches.
206 637 4071
Old 11-11-2009, 10:02 AM
Lost lock key
I have also been in this situation with customer and my own vehicles. I have found a 1/2 drive impact socket that is slightly small can be driven on and will remove the nut. Usually means less chance of damage to the wheel than some other methods.
Good Luck ,and a good Veterans Day to you
Old 11-11-2009, 10:05 AM
You can try a Bolt-Out, craftsman sells them. Hammer the tool on to the bolt and use an impact to get it off. Don't bother trying to turn it off with a hand ratchet, you need the impact. Or an air hammer with chisle tip. I just got mine off this way. They were a slightly different design though.
Good Luck.
1986 Targa
1993 Corrado VR6
2005 325xi
2010 135i
2011 X5d
Old 11-11-2009, 10:10 AM
they are not bolts that you can hammer anything over. picture just the bottom curved part of an alloy lug nut. horrible design. even if you have the tool, the tool bends or breaks, unless you don't torque it much, then what good is that, safety-wise?
206 637 4071
Old 11-11-2009, 11:32 AM
1986 Targa 1972 RS clone
magnuskgc's Avatar
Plasma cutter! Just kidding hope it doesn't come to that
Old 11-11-2009, 11:47 AM
jonesb930's Avatar
No luck with the punch. The piece is aluminum and it just deforms it. I am trying to save the wheels to put up here for sale. I have determined that the holes are 1/8th inch. I am going to try to get a few dowel pins and use one of those "Universal" sockets with all of the pins inside. I tried it for size with some steel rod and I think it may work. The steel rod just bent over though. If this fails I may try Johns idea and pick up a 3/4" hole saw. As John said "poor design". The last time I used the tool it was missing a few pins already.
Bill Jones
Jupiter, FL
Old 11-11-2009, 12:17 PM
JW is absolutely correct--the nut is flush with the wheel and there is nothing to grip onto. His suggestion of the 3/4" hole saw is probably the best. I have the same type lock on my 912, and as John mentioned, the key broke while trying to remove the wheels. Poor design and totally useless once the key breaks.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-11-2009, 12:20 PM
"farking Porsche hero"
Rich Lambert's Avatar
I had this happen and ended up going to the Porsche dealer. They had a jig for drilling off locking lug nuts. Worked like a charm and no wheel damage.
A tip...do not go to a tire/wheel place for this, no matter what they tell you.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 11-11-2009, 12:33 PM
Peter Zimmermann's Avatar
The best way!
Keep the Shiny Side UP!
Pete Z.
Old 11-11-2009, 12:54 PM
jonesb930's Avatar
My dowel pin idea did not work :-(
I picked up a 3/4" hole saw and will give that a try tonight after my little pit monkeys go to bed.
Bill Jones
Jupiter, FL
Old 11-11-2009, 05:19 PM
JMatta's Avatar
Wheels locks are such a pain in the a**. Nobody steals wheels anymore, they just take the whole car.
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 11-12-2009, 06:29 AM
I had to do this myself. I went to Pep Boys and the mechanic told me what to do.
Put a pointed chisel bit into your air hammer. Place the point in the groove of the lock. Keep the chisel straight no need to twist or turn. Keep hard pressure so the chisel doesn't pop out and hit your rim. Pull the trigger it will start to spin the lock and loosen in a few seconds.
It works. I had to do all five on my SUV when we lost the lock. All five were off in a matter of minutes. FYI- I didn't buy another set of locks.
Good luck.
Old 11-12-2009, 06:44 AM
jonesb930's Avatar
I was able to get some time tonight to try Johns suggestion. The ring came free and i stopped drilling. There was a very small portion left however. Also the threads were still on the stud. This prevented it from being removed. I tried several ways of getting the rim off without further drilling but had no luck. I ended up having to drill completely through the rim. Not a big loss. They were poorly fitting 16" BBS Look alike 1 piece rims. The new rims are now on one side of the car and they look great. The fitment is perfect now! They really transform the car.
John Walker sir, I owe you a Cold beer if you ever get here to sunny South Florida my good man!
Bill
Bill Jones
Jupiter, FL
Old 11-13-2009, 07:42 PM
i ground down a small chisel to get the thin shell off the stud.
206 637 4071
Old 11-13-2009, 08:55 PM
I had the same problem on an 89 Carrera and the local Porsche dealer in Burtonsville, MD (Tischer) removed 4 of the locks at no charge. I could not beat that deal. Good luck.
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 11-14-2009, 07:11 AM
Woodyhfd's Avatar
You may want to try one of these:
Gator Grip Universal Socket
1987 911 Coupe, Diamond Blue Metallic
2006 Cayman S, Seal Gray
1983 911 Targa, Black: The Dirty 911 (GRM)
Old 11-14-2009, 12:07 PM
