a.k.a. G-man
Geronimo '74's Avatar
Going from 3.2 to 3.4, some questions.
I am planning of doing an engine rebuild in the very near future.
The engine is a ROW 3.2 from 1986, 915 tranny.
I would like to go to a 3.4 with S-cams. I would also like to keep the Motronic engine management (but maybe with custom chip).
In Wayne's rebuild book the 3.4 upgrade is one of his top engine picks.
And it says it is a bolt on solution.
So if I buy a set of cylinders and pistons (98mm Mahle), do I just swap them with the ones I will be removing????
Or are there special things to pay attention to???
Things I have to change, adapt, modify??
Any guesstimates on how much hp I will gain compared to the stock setup?
If more info is needed, let me know.
Thanks for the feedback guys!
Old 11-14-2009, 12:22 PM
3.4 Bigger is better
88-diamondblue's Avatar
The P&C's are a direct replacement for the 95's. I am not sure about using an S cam on a Motronic engine. Talk with John at Dougherty Racing Cams about what you want from your engine. The cam will determine the personality of how it drives. Do you want more torque with less high end or do you want the power to come on at higher rpm's? John can guide you on this. Another question is what compression ratio are you wanting to go with? That will determine if you need to twin plug the engine. Many variables based upon what you want from the rebuild. You will need a chip to take advantage of the 3.4 upgrade. I did the SteveW custom chip as this is needed for anything other than a 3.2.
If you are looking at Mahle P&C's I would consider using the Nickies from LN Engineering Nickies The Original and Genuine CNC Billet Aluminum NSC-Plated Cylinders and going to the slip fit 3.5 P&C's. From a price perspective I don't think there is much difference in price and JMHO a better choice. If I had the budget it is what would be in my car. A true 3.5 upgrade as the 3.4 is not really 3.4 only close.
On my rebuild I used QSC/JE 3.4 P&C's, DC-22 cams, performance springs, ARP rod bolts, I was looking for more performance and am happy with the outcome. Using a Dynolicious app on an ITouch I recorded 258 hp. I had SteveW set the redline for 7200 rpm since I was hitting redline at 6800 all the time. Now it feels natural to shift by 6900 to 7000 and there is very good power until that point. Dyno next spring to actually see where the most power is being made at.
Biggest thing I learned is to figure out what you want from the engine, where do you want the power at. Talk to people like John@DR Camshafts and SteveW about it. They will be able to answer your questions about what works the best for what you want.
There is a thread here at PP which I haven't been able to find that shows the build of a 3.5 engine and all that was done. Will find and post later.
I have been very satisfied with the 3.4 upgrade and would recommend it anytime. Just know what you want from it, use the knowledge from the many people (both pros and and the rest of us) to what works and what fits in the budget to achieve it.
A shot of 3.4 P&C's installed
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 11-14-2009, 02:11 PM
AutoBahned
RWebb's Avatar
Let's see... 3.4/3.2 = 1.0625
so you get about 6% more hp for a LOT more $$ (unless your P & C's are so worn they need to be ash canned anyway.
Old 11-14-2009, 02:49 PM
Porsche rated the engine at 217 and I am pushing 260. Definitely more than 6%. HP on Porsche is not cheap. The driving experience is considerably different than before the rebuild.
Michael
2020 Honda Passport
Old 11-14-2009, 03:08 PM
CC= cubic cash on Porsche
Old 11-14-2009, 06:49 PM
MBruns for President
JeremyD's Avatar
I'm happy with my 3.4 - and I have a new engine. With high lift cams I'd recommend you replace all the rocker arms.
I'm getting a little more then 6%
Old 11-14-2009, 07:24 PM
175K911's Avatar
This is part of what concerns me about building a 3.4 vs just dropping a 3.6 in my '86. I've had my car dyno'd on a very conservative Dyno Dynamics machine (known locally as the heartbreaker because it debunks lot of high hp claims made by some parts purveyors) and it put down 202 whp. If you use the 15% assumption, that's 230 at the crank. Stock 194K mile 3.2 with George Narbel headers, Ben's 911R M&K muffler, and a 15 yr old Autothority chip. Going from my KS pistons to JE 98mm 9.5cr, if I apply the 6.25% displacement I'd get 245hp, maybe 250 if you consider a slight increase in CR. Add a mild 964 grind cam, extrude hone the intakes, and a fresh rebuild, perhaps 255-260. 25-30 horse for $7500 in parts and machining costs alone seems to be darn expensive horses. I can take an off the shelf stock 964 3.6, put my headers and muffler on, retune the software and get 265-275 hp, with lots more torque.
If I factor in selling my current 3.2, I can do the conversion for less $$ than building a 3.4. More power, more torque, potentially more reliable, twin plug iginition, less $$. Hmmm. What's the purpose of the 3.4 single plug conversion? Not trying to downplay the 3.4 since it's still under consideration. But for a track car that sees maybe 500 miles a year on the street, help convince me why a 3.4 is a better value than dropping in a 3.6. Even if they cost the same.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 11-15-2009, 06:32 AM
Venetian's Avatar
How about a gear ratio change for a little more get up and go? I assume it would be somewhat cheaper, simpler and perhaps as effective. Anyone have any experience with this for comparison? I'm assuming most people are looking for increased acceleration rather than top end.
1987 Carrera, Venetian Blue.
Old 11-15-2009, 09:57 AM
a lot of the discussion about buying a 3.6 and it being lots cheaper than rebuilding a motor into 3.4 circles around a pretty large assumption: that the 3.6 you bought is in great shape. Of course its a testament to Porsche reliability that many of us have installed used motors, chipped, headered, and raced them for long periods of time. But you have to assume the risk of that gamble too. You could just end up buying something that was neglected or has a huge amount of miles. How old is the newest 3.6 at this point? If the owner had covered 3k miles per year, you could be buying a worn out motor.
I agree that its always much easier to buy , plug and play. And posters are also correct that the larger displacement gives you more hp right out of the box. Just be heads up on what you are purchasing when you consider buying a used engine compared to rebuilding
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 11-15-2009, 10:28 AM
ZAMIRZ's Avatar
Another option to consider would be 100s with JE pistons from LN Engineering. I run them in my TRE-built ROW SC (now a short-stroke 3.3) with just about everything else stock and it makes a mountain of torque in the mid-range and keeps pulling until the tach needle is pegged.
http://www.lnengineering.com/911.html
Amir
'83 911SC
Old 11-15-2009, 10:35 AM
m110's Avatar
When (if) I need a top end rebuild of my 3,2 I was considering this modification. Modifying for power and rebuilding due to wear are two different scenarios. Do the 3,4 L conversions pass smog in CA with the modest increase in compression and still single plug? Is this even an issue with a small displacement increase?
Although putting a 3,6 in is perhaps cheaper, it would be more fun for me to build up a 3,4.
1988 Carrera Coupe
Old 11-15-2009, 10:54 AM
Technically speaking, any modification other than stock, has to be California Air Resources Board approved. And there are precious few porsche performance items that pass those regs.
BUT, can they see inside your engine for the mods? Nope, but you are responsible to have the car tuned correctly to pass emissions, so a larger displacement motor can have the chip tuning that will meet the tailpipe standards and yield more hp and torque while meeting your moral responsibility
1970 911 Targa "ST"
Old 11-15-2009, 10:58 AM
m110's Avatar
Does the throttle body or flapper box arm need to be modified?
In terms of morals...
Originally Posted by TRE Cup View Post
...a larger displacement motor can have the chip tuning that will meet the tailpipe standards and yield more hp and torque while meeting your moral responsibility
mor·al (môrl, mr-)
adj.
1. Of or concerned with the judgment of the goodness or badness of human action and character: moral scrutiny; a moral quandary.
2. Teaching or exhibiting goodness or correctness of character and behavior: a moral lesson.
3. Conforming to standards of what is right or just in behavior; virtuous: a moral life.
4. Arising from conscience or the sense of right and wrong: a moral obligation.
5. Having psychological rather than physical or tangible effects: a moral victory; moral support.
6. Based on strong likelihood or firm conviction, rather than on the actual evidence: a moral certainty.
I might argue it is my moral obligation to resist such emissions legislation that are not effective and detrimental...but that's another discussion.
1988 Carrera Coupe
Old 11-15-2009, 11:19 AM
175K911's Avatar
Hey TRE-
You're absolutely correct on several fronts:
The 3.6 could also need to be freshened up. Always a risk. But before installation I could pull the heads, install ARP rod bolts, 993 head studs and be reasonable certain that the engine would hold together for a few seasons.
I don't need to worry about emissions in IL on my '86 especially for mostly track.
With proper chip tuning, the 3.6 will make good torque.
My goal was to consider alternatives. My 3.2 needs a top end at least. At 194,000 miles and with completely unknown history, it's time. When I had the headers off last winter, oil dripped from cylinders 1 and 6 past the guides and seals. And it still have one piece oil return tubes on it. But I still have between 4 and 6% leakdown and the engine doesn't use any noticable oil in an entire weekend at the track. But every morning it smokes enough to kill all bugs within 50 yards. I've run this engine for two years (probably 40 days) on the track and have done nothing but a healthy diet of Brad Penn every other event. I don't want to tempt fate and have an exhaust stem break because of the slop in the guide.
I like the idea of a 3.4 because of the shorter stroke and freer revving nature of the engine. But the 3.6 just makes so much more torque and with twin plug can get away with the higher compression on 93 or 94 octane pump fuel. There are turns at some tracks I'd like to take at 4500-5000 in 4th rather than 6000+ in 3rd because I just run out of revs too soon at track out. So it's a catch 22- which way to go. The 3.4 would be fresh, and happy at up to 7200, but the 3.6 can be driven using lower rpms and taking advantage of a healtier torque curve.
ZAMIRZ- the 100's would require more work (ie $$) to work with Motronic. Charles Navarro is local to me and we've shared thoughts. The good news is that he can bore my Alusil barrels to run the 98 J&E's. Saves a boat load. If I went with Nickies, the parts and machine shop bill would quickly reach $10K and for that I can pull a 3.6 apart to freshen and install for less $$. I'm one of the 10.2% who got "retired" by this crappy economy so I've got to watch the 911 $$$ carefully for now. I need to rebuild the 3.2 but think it would be a shame to just rebuild stock just to save a few dollars.
Thanks for all the thoughts everyone.
That's the beauty of our cars, we have choices.
Ed
Old 11-15-2009, 11:58 AM
Jeff Alton's Avatar
When you start getting power out of a 3.4 you end up with a motor a fair bit different than a 3.6, at least I did.
Going bigger cams, ITB's and twin plug (10.5cr) I got a motor that made peak HP at 7000 and was flat from there to 7400. It has an amazingly flat torque curve as well starting at 3200. Not the sort of torque one may get from a 3.6, but still plenty. With the ITB's you get major league throttle response.
I built the 3.4 more for its character (like a big early "S" motor) than outright power, even though it makes lots of HP. I had rebuilt a 3.6 longblock and sold it to build the 3.4.....
I think if you are staying with the 3.2 intake, the BIG reason to go 3.4 would be if you needed a set of P/C anyways. Then it is the same money. I would go a little more cam than a 964 (which I really like in a 3.0) and would maybe look at a DC20 or even a bit more.
If you have SSI's now (already a bit small on a 3.2) you would need to consider moving up to 1 5/8 headers (or maybe 1.75 if you ditch the intake and go with a big cam and more compression).....
Cheers
www.turn3autosport.com
Old 11-15-2009, 03:04 PM
AutoBahned
RWebb's Avatar
Porsche rated the engine at 217 and I am pushing 260. Definitely more than 6%. ...
I expect that you have done other things to the motor, or do not have accurate hp measurement (say, a road dyno - which is a notoriously inaccurate way to measure hp). Also P AG rates hp very conservatively, so your motor likely p[ut out more hp than that originally.
Old 11-15-2009, 04:37 PM
Geronimo,
What are your goals for the car and do you have to deal with certification or smog concerns in Belgium?
A stock long block 3.2 can make up to 270hp. Even with the stock intake in place.
For me, a well tuned 3.2 Carrera with a good suspension set up, proper wheels, and some lightening is a great car. Anything much past that is a lot of dollars chasing marginal improvements.
Having said that, it would be cool to basically build a 3.2 911S. Lighten the car to 2300 lbs w fiber bumpers + lids, run a cam aggressive enough to make it act like a 2.2S, new rods that can turn to 7300rpm, and carbs. Add close ratio gears and it would be a major blast to own and drive.
Back to reality, 3.2 Carrera's respond very well to exhaust and chip changes. If you can get to a 1 3/4's equal length header system w a proper sport muffler, aftermarket rod bolts, and a chip tuned to use your euro compression / fuel, and turn to 7k rpm, you will have a great motor that can make up to around 260hp.
Thus, if your euro P&C's are still in spec as they should be if you are under 200k, keep the $3500 for other goodies like suspension, light weight interior, track fees, and leave the contents of the front trunk at home to save another 50 lbs.
With 260hp pushing 2500 lbs you will have a wonderful car.
Adding 5% more power over a well tuned euro 3.2 by making it a 3.4 would just be and extra spoon full of gravy.
Old 11-15-2009, 05:43 PM
Biggest thing is to decide what is important to you from the engine. A 3.6 may be a better way to go. When I started I expected to put new studs in and do a valve job. Not really anything else. Ended up doing a full rebuild, new P&C's, high lift cam, many things refreshed and set up to be able to handle rpm's well over 7000. I learned a lot and my engine is what I imagined it would be, just took a little longer to get there than I planned. (rookie mistake).
JeremyD's engine has 20 more hp than mine as I believe he (Jeremy, correct me if I am wrong) flowed the intake and opened up the throttle body plus his exhaust allows better flow as well. The exhaust mods are on my list of things to do.
I spent around $6500 for my rebuild. The budget for me was a limiting factor but did all the right things if I want to more performance later on.
No budget I would have done the 3.5 Nikies/JE since they would handle high lift cams, not so sure the Mahle's will.
The car drives much different as corners that were taken in high RPM are now in the next higher gear in the 4500-5000 rpm range. I am learning to use the new power that I didn't have before.
Here is the thread I was looking for on Ralph's Carrera3.5l rebuild. I think there was even more power to be had if you aren't worrying about emissions. Pretty conservative of what you could get from this engine. Here are the links.
3.2 to 3.5 - Part II
Dyno results, remember this is with 91 octane pump gas.
3.2L to 3.5L Dyno RESULTS
Michael
2020 Honda Passport
Old 11-15-2009, 06:16 PM
JeremyD's Avatar
Dave - how many 3.6's have you opened up that haven't needed valve guides? When I asked my local wrench that question - out of 100's he could only name a handful. How many have you opened up that haven't shown layshaft bearing wear? - That number was also pretty small. I sleep better at night knowing I have pretty close to zero oil usage, I have new bearings and rockers. I have six new valves and new guides. You roll the dice - sometimes you come out ahead, some times not so much.
from my dyno
Originally Posted by Steve W View Post
SAE Corrected value is 244 rwhp at appx 6300 rpm at an AFR of 13.0-13.1. That's Ralph's 3.5 territory. Must be that 93 octane gas out there. With a little fuel tweaking, we can extract a couple extra hp in the 5000-6000 range.
For comparison, here's Jeremy's 3.4, in blue, compared to Ralph's 3.5, in red, compared to a bone stock 88 3.2 with a euro premuffler and stock chip, in green.
Old 11-15-2009, 06:26 PM
JeremyD's Avatar
BTW - just came back from a day at sebring and my car ran like a friggin top - I passed a few full out D and E full race cars - even with my extra weight the performance is good. Yes you have to drive in the upper rpm's - but what Porsche can you drive (or want to drive at 3,000 rpms's anyway?)
Old 11-15-2009, 06:29 PM
