I need a softer set-up ???
I live in Tucson,az,...and the roads here are not good at all,..I now have adjustable Koni's on the front(soft setting) and it beats me up,..I dont flow over the roads I bounce over them and they are truely very rough how can I soften the ride.It feels like Iam going to snap something driving local roads ????? TIA Frank
What are your suspension specs now?
Torsion bar size Koni yellow or red what are the rear shocks ride height tire size
Chuck Moreland - elephantracing.com - vonnen.com |
I belive its stock,...I have a 77' Targa and I used red koni's,...FM
as for ride height its very low set at around 24" maybe 24.5 front and rear...I dont know what the bar size would be...15" tires aswell FM
Almost Banned Once
There's not much you can do to soften it up without swapping out components.
I have a through body Weltmeister anti roll bar on the front. The ride on my car was very harsh when i bought it. I moved the link arms further out on the adjustment arms and this had the effect of softening the suspension. Also adjusted the rear - Weltmeister as well. They were almost hard against the stops when I bought the car. You car being stock would have the non adjustable bar that is installed lower down outside the body. I'm not sure if this helps.
- Peter Last edited by sc_rufctr; 11-16-2009 at 06:22 PM.. |
maybe check the bushings
the ones on my 78 are beat, replacing them as we speak also a return to a normal ride hieght may soften things up cant wait to hear from the experts thanks for the question
1978 911sc Targa Sold 2001 996 Cab Sold 2006 Cayenne S Silver Wifes Car for sale 2011 Jeep Wrangler Silver for sale 2010 Toyota Prius Black for sale 2016 BMW 328D wagon |
But it looks like the problem is your car is too low. With stock tbars and that height, you are likely hitting the bump stops regularly. That makes for a very harsh ride. Increase ride height or make suspension mods to allow you to safely run that low height.
Ok Chuck Thanks ,. but what type of mods could be done,I have little experience with P-Car suspension
Oh I will need to ck on the tire size,....Thanks Frank
man I measured my ride height (rear) 23" yes 23 " I sure thought it was set at 24" in 05' Bad shocks ???? FM
