removing shift knob?
hi,wondering if anyone knows how to remove the factory shift knob on an 1984 targa,keep reading things about a crush sleeve,i dont want to damage anything,thank you!
Old 12-18-2009, 08:48 AM
fred cook's Avatar
Try placing an open end wrench that will span the shift lever under the knob and tap upwards with a hammer or other suitable bludgeon. There is always the risk that you might crack the shift knob, but I don't know of any other way to remove the knob from the lever. Good luck!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 12-18-2009, 08:54 AM
aj88cab's Avatar
Your '84 (Carrera) has a bolt under the plastic cap on the shifter.
Edit: Ahhh...maybe thats only the G-50s ...sorry...
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 12-18-2009, 08:57 AM
Regis turd ab user
Heat the shift knob with a hair dryer or heat gun and twist off. If it is cold be careful applying the heat as not to crack the clear top.
Old 12-18-2009, 09:05 AM
joefrantz's Avatar
If it is a crush sleeve (I'm not sure about 84's) they are very easy to remove with a strap wrench -- just wrap the band around it and twist. I've never been able to get one off using the open end method without damaging it.
Joe
Joe Frantz
73 911 T
Old 12-18-2009, 09:06 AM
emac's Avatar
Well a few years ago I had to attempt the same thing. I know that I had read a thousand posts about the wrench under the knob which I tried. Started slow and as hours turned into days and a trip to the hospital for stitiches because of me being soo pissed off, I about put the wrench through my head. I know the original are worth a few bucks but at this point I pulled out the Dremmel and haven't looked back.
Ernie 81 SC
Old 12-18-2009, 09:07 AM
Somatic Negative Optimist
Gunter's Avatar
Penetrating Oil !!!
If it's the same as as the knob on an SC, like Fred says, place the open end of a snug fitting wrench under the knob and tap upwards.
Important: Spray penetrating oil (Not WD-40) through a small nozzle from underneath into the Knob/crush sleeve before anything. Wrap a rag around the lever to catch the drip.
You can use the right size or an adjustable wrench underneath the knob.
Very little room to swing, so, I used a 4 lb hammer flat-side to give it a good tap.
Mine was tight and heat or twisting didn't work but the spray, open end wrench and the 4-lb hammer worked fine.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 12-18-2009, 09:12 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
I would add to Gunther's method. Put a piece of leather or something inside the wrench head so you don't mar the shift lever.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 12-18-2009, 03:20 PM
gtc gtc is offline
abides.
gtc's Avatar
Just grab hold of the knob and pull like crazy. Try not to hit yourself in the face when it comes loose.
Graham
1984 Carrera Targa
Old 12-18-2009, 04:04 PM
gtc gtc is offline
abides.
gtc's Avatar
"Get your mind out of the gutter!"
Graham
1984 Carrera Targa
Old 12-18-2009, 04:07 PM
Senior Advisor
James Brown's Avatar
Unmolested, those knobs are almost priceless. Think what you are doing and why your doing it so you don't have to pay $300.00 for a new one (along with the ER bill).
Watch there next post will be "Can't get these #%&*@ pistons off the connecting rods, tried to pound them off and hit my finger, now back from the hospital, any help?"
Sometimes mechanical things are best left to the mechanics...
08 Cayenne Turbo
Old 12-18-2009, 04:18 PM
gtc gtc is offline
abides.
gtc's Avatar
Actually, Porsche is going to be making these knobs again soon (if they aren't already).
911 424 071 01
http://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/neweditions/
Graham
1984 Carrera Targa
Old 12-18-2009, 05:05 PM
Senior Advisor
wow that stuff directly from Porsche? New fuchs wheels, chrome engine intake, new shift knobs. That's there (VW) new way of getting out of debt! Make the parts we all want! concept.
08 Cayenne Turbo
Old 12-18-2009, 05:20 PM
Dixie Region R Gruppe
w21055's Avatar
Wow, so we can walk into the dealer and ask for these?
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 12-18-2009, 05:45 PM
joefrantz's Avatar
or possibly order through Pelican -- not sure how these items will be distributed.
Specifically re the shift knobs, my '73 is made of Bakelite -- very brittle and prone to cracking and shattering. I suspect that later years were made from more contemporary plastics. I'll be interested to see what materials are used for the new ones.
Joe
Joe Frantz
73 911 T
Old 12-18-2009, 06:02 PM
w21055's Avatar
Got some list prices today
911 559 041 02 = $971.03
911 424 071 01 = $112.85
911 361 020 10 = $1057.87
901 424 014 00 = $167.84
Shift knob is not that bad but wow on the Fuchs!
1992 Ferrari 348TB
Old 12-22-2009, 06:40 AM
Just pull, be careful when you put it back on, the crush sleeve goes in past a ridge. If not in place it will crack your knob when replaced back on the shaft.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-22-2009, 05:56 PM
Just curious, when you remove the factory shift knob without breaking it, does the crush sleeve stay in the knob and can it be re-used?
'84 Carrera
3.4 twin plug
Old 12-24-2009, 11:30 AM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
lmao
been there done that once......just once.
blood on black vinyl is easy to fix...a chipped tooth ithn't
i now have an alloy momo one with set screws to hold it in place
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 12-24-2009, 11:50 AM
teenerted1's Avatar
maybe/yes
Ted
Old 12-24-2009, 11:51 AM
