Bent Engine Cross Bar
Hi,
I'm in the process of cleaning up all the pieces on my engine prior to putting it back in. I was cleaning the rear engine mount(cross bar + mount console) and noticed that the bar was pretty well bent.
What are your thoughts? Is it worth it to hammer it back to straight? Should I just get a straight used piece?
Pictures:
1973 911T | Four owner car | My stewardship (2008-Present)
1972 VW Super Beetle | Two owner car always in the family | Gone, but not forgotten
Old 12-27-2009, 02:57 PM
Platinum Member
dad911's Avatar
Some engine mounts are threaded, and some use a through bolt. If this was threaded, it looks like it was torqued upon removal?
Inspect the welds, but I would either replace it or straighten and reinforce it.
Old 12-27-2009, 03:02 PM
It is the threaded kind. Thanks for the advice!
Old 12-27-2009, 03:08 PM
Max Sluiter
Flieger's Avatar
I think it would be best to find a straight used part. Just my. $.02
Old 12-27-2009, 05:53 PM
I would replace that one too.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-27-2009, 06:07 PM
Used Porsche Parts shop order placed.
Thanks!
Old 12-27-2009, 06:13 PM
There's little to counter-hold the end of the mount bar while removing/replacing the engine mount bolt, so it was probably bent when the engine was removed once upon a time. If you can straighten it, fine, but either way, I'd suggest drilling out the existing threads and use a through bolt, washer and nut; same as the orig. motor mount bar in '73. The later motor mount bar uses just a threaded bolt into each end.
Sherwood
Old 12-27-2009, 08:14 PM
