LinkBack | Thread Tools | Rate Thread |
Go Speedracer, go!
What can I add to gas to boost my octane rating for safety margin?
I'm editing my original post to facilitate those who don't read through the whole post.
I found a source for high octane race fuel locally (thanks to those of helped me!). From the information I have been provided by all the people here smarter than me, I have decided that high octane race fuel is the only safe sure way to increase my octane level. I realize that I will not be operating my car at 9/10ths during my first track day. Below I stated I hopefully will be, but many have informed me I in fact won't. Whatever level I am able to achieve is irrelevant, since I am simply looking for a way to increase my safety margin to protect my engine. Now, back to the original post I made 3 months ago... --------------------------------------------------------------------- My significant other got me a high performance driving school session for Christmas. I have spent the last few years preparing my car to be track worthy. It is 99% there. I just have to replace the master cylinder and pick up a helmet and it will be ready to go. I am worried about detonation destroying my engine during a track event. Since I'll (hopefully) be driving it at 9/10ths the majority of the time, I presume it will be running very hot. It is a euro SC with 9.8:1 compression ratio, so it's borderline as it is. At a recent dyno run, the tech mentioned that it looked like it could be detonating in the 6,200 - 6,600 RPM range. I know those octane boosters you get at the FLAPS are bogus, so what can I add to my gas for this track event to protect the engine from detonation? Toluene, MTBE? And, how much do I add per gallon of gas? Is it safe for the CIS system to add any of these additives? I know you can get toluene at Lowes/Home Depot, but I would need to find a local source for any other additives that might work too. Thanks for any help in advance!
1981 SC ROW Coupe Last edited by SpeedracerIndy; 03-26-2010 at 07:34 AM.. |
(the shotguns)
you need to address the possible detonation on street gas.
and/or start buying drums of race gas. as i recall mixing various octane ratings of gasoline gives you easily calculated new octanes. that is to say the increase/decrease in octane is proportional. 50% 93 and 50% 102 would give you 97.5.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Caveman Hammer Mechanic
"Klotz Octane Booster is a concentrated tetraethyl lead substitute formulated to increase the octane rating of gasoline up to 10 numbers or more. Helps eliminate engine damaging detonation, spark knock, pre-ignition, and pinging from low octane gasoline. Octane Booster modifies the burn speed and flash point of gasoline to create a stable combustion chamber flame front, maximizing performance and power. Stabilizes oxygenated gasoline to prevent lean-out conditions. Klotz Octane Booster provides needed upper cylinder lubrication that is missing in unleaded gasoline."
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Soldier of Fortune
You need to add high(er) octane gasoline.
Hey,
You can also go to your local general aviation airport with a couple of jerry cans and buy 100LL av gas. Don't do this if you are running a catalytic converter or will be in the near future, the TEL residue will trash the converter. It will eventually pass, don't know how long it would take though. Another option is to go to your local motorcycle shop and buy 5 gallon cans of race gas. Good luck eric
Go Speedracer, go!
No catalytic converter here, my car has SSIs with an M&K muffler. Good ideas, thanks. I should start researching race fuel in my area. I'm in Indy, so there has to be a plentiful supply.
1981 SC ROW Coupe Last edited by SpeedracerIndy; 12-28-2009 at 09:42 AM.. |
I've been told that an MSD ignition unit will help with lower level detonation too but I'm just drawing from memory.
1982 911SC 1987 924S |
Where is your track day at ?
Most tracks have fuel (good stuff) right there. If you plan ahead you could show up with 1/4 tank and do a 1/4 more of some race fuel (or 1/2 & 1/2 .. but you get the picture) blend it ... I would doubt that you really need 100% full on highest available octane. Motorcycle after-market places (not always the dealers) will have fuel in 5 gal drums.
Brian Enjoy Life ... Eat out more often ! Last edited by Wyvern; 12-28-2009 at 08:38 AM.. |
For tracks that I go to that do not sell race gas (some smaller ones), I take a fuel jug or two with me. Check around some of your local race prep/engine build shops and they most likely have race fuel they will sell you. 5 gallons of 100 octance race fuel mixed with 15 or so gallons of 93 octane should work fine in your application.
I'm running 10.3:1 compression, BTW.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Absolutely correct!!
Octane boosters all have issues with "collateral" damage; some of which you can see and some manifests itself later on. I would not use those for what you are doing. Unleaded race gas will do the trick for track days and a Google search should show you where you can buy it in your area. Stay away from aviation gas for two reasons: its full of lead that ruins the oxysensors & cats and the octane is NOT the same as R+M/2 at the pump. Further, its formulation is intended for smooth burning at high altitude and it burns too slowly for sea level use in automobile engines that run at different RPM's.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
gearhead
This is a little OT, but since Steve is here participating I am going to ask the question because I want to know his answer. What about E85 in our air cooled cars? We're using it very successfully here in Colorado in modern vehicles, but what about the old CIS cars that don't have an ECU that you can retune/reflash. Is a 10 or 15% mix of E85 with pump premium an option for the OP's application?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Go Speedracer, go!
1981 SC ROW Coupe |
Go Speedracer, go!
1981 SC ROW Coupe |
My guess would be no. You need to increase the amount of fuel around 40% for proper fueling with E85 and you would have to seriously modify a CIS FD to do this.
Paul |
using pump gas, go back to the dyno, retard your timing a few degrees. do a comparison of the numbers. you may not loose any HP. the dyno is the way to set the timing anyway, advance it until you no longer see any HP gains.
make sure you have no air leaks, you do not want to be lean try one step colder plug, if you are tracking it, you can run a colder plug anyway.
I just got off the phone with Matt on this subject but I'll try to summarize.
The use of E85 is a real bad idea for all Porsches built before 2009, despite the 116 octane (RON) of Ethanol for several reasons. Here are just a few: 1) Ethanol is hygroscopic and the absorbed moisture facilitates and accelerates fuel system corrosion of any non-stainless steel parts. 2) Ethanol attacks and dissolves elastomers in the fuel system thats not made from Viton. This means that any rubber parts: gaskets, seals, O-rings, fuel lines made from rubber will suffer. 3) Ethanol has 1/3 less BTU's per gallon and as such, requires richer fuel mixtures than gasoline. The fuel pump, injectors, and FD (CIS) components require upsizing to deliver sufficient fuel volumes to maintain Stoichometric or better, air-fuel ratios. In some cases, there are no options to do this. 4) Ethanol is a powerful solvent and washes the cylinder walls of their lubrication. Ethanol dilutes regular engine oils so special oils are needed to control engine wear. Remember, OEM's are not concerned about this; the motor simply must make it through the warranty period. Race cars using straight Ethanol use special oils for this fuel and E85 isn't THAT much different. 5) Ethanol is very detonation resistant, however an engine using E85 really needs different ignition timing maps (advance curves) and more compression to take advantage of this fuel's characteristics. This is not a bolt-on proposition and may render the engine unable to run safely on normal (E10) pump gasolines. This is a very complex subject and I've just touched on the highlights. If I had time, I could write a book on this,..... ![]() I do hope this helps,
could this change the mixture? i connected the LM2 to my car when i was driving home from charleston. at first i was seeing a little over 13 at idle, i know, rich, i had just bumped it a little more rich to see how it ran. but the main thing was, at speed, my mixture changed from around 15,avg, to 16 avg. BTW, not to hi jack, but ethenol was brought up and the need for mixture change, so this may be helpfull. anyway, this was on the hiway so it was steady speeds. i did fill up, cant rememeber if it was in the middle of taking readings. if i did fill up and filled up with a higher ethenal gas, would it appear leaner?
thanks for the info on ethenal steve. as far as the OP, i still say retard 2-3 degrees and check on a dyno with pump gas.
Your LM-2 will show the differences,...
