thermo fan for A/C evaporator?
Hi All,
Has anybody ever put a SPAL style thermo fan on the evaporator of their air conditioning system? I don't mean one in front of the evaporator to push more air into the evaporator. I mean it being used to pull the air through the evaporator and out the aircon vents. It seems that the latest S style fans produce heaps more cfm then conventional fans.
Could be a way to get more airflow? Opinions?
Thanks,
Adam
_____________________
'73 RSR Interpretation
Old 12-09-2009, 08:17 AM
I have thought about that as well and I cant figure out a way to make it work because of the way the plastic housing is manufactured for the evaporator. The supply air fan is mounted above the evaporator. The delivery air is sent into the cabin via an aircraft hose/duct. Removing the housing for the fan makes the mount for the hose/duct disappear. The centrifugal fan that Porsche designed does do the job if it is working correctly mounted down on to evaporator base so it won't rattle. If the clips are broke get a couple of small towels and lay them across the top than gently close and latch the smugglers box door, it will quiet things down.
The real issue with the 911 AC system is not the evaporator or the delivery fan it is a lack of condenser heat exchange to get the freon cold enough so when it goes into the evaporator it sends colder air into the cabin. I am adding a cold air kit (additional condenser and fan) into the drivers side rear quarter panel wheel well this spring, $599.00.
Zim's Autotechnik 911 A/C COOL Kit, 78-86
Old 12-09-2009, 08:40 AM
funny you mention that kit. I am just about to order it. Everything I've read about it has been positive.
I'm just trying to find a way to create more air volume coming out of the vents...
Old 12-09-2009, 08:46 AM
Barrpete's Avatar
Griffiths makes an upgraded evaporator fan that pushes a lot more air than the stock unit. The only trick is that it will only fit the evaporator box for the '85 and earlier so you have to source that style box.
Porsche, 911, 930, fan, motors, blower motors
Also, if you're going to pull the evaporator check to make sure its not simply clogged up. When I removed mine it was full of crud.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 12-09-2009, 11:31 AM
Any word as to why they don't make that fan for the 87 on?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 12-09-2009, 06:09 PM
Throw it on the ground!
Answers and pictures why here:
Anyone here with a 1986+ done a Kuehl Wirblesturm "Hurricane" evap motor upgrade?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 12-09-2009, 07:14 PM
so judging from the picture of the later style evaporator box, it seems like a thermo fan would fit nicely.
Do you think the thermal fan would produce more airflow then the stock one? The motor on the thermo fan does seem to be much smaller...
Old 12-12-2009, 10:34 PM
kuehl's Avatar
Originally Posted by StayGold808 View Post
Hi All,
Thanks,
Adam
At this time there is no 'spal' or pancake style fan that produces more air (cfm), placed as you suggested, either pulling or pushing, as compared to the OEM motor with Squirrel cage. If you need more air you could use the Kuehl Hurricane Motor along with any Behr evaporator box top and metal squirrel cage wheel that is pre 86. Kuehl has not produced an upgraded fan motor yet for the 86+ cars because it is more cost effective to locate a used pre 86 evap box top and metal squirrel cage wheel as opposed to making a new mold and producing a new box top and wheel; (you can source a used Behr brand pre 86 box top and metal squirrel cage blower wheel to use with the upgrade Kuehl motor here in the Pelican used parts forum or from your local Porsche salvage yards).
Old 01-08-2010, 09:22 PM
