Outer Window Scrapers on doors.
I have no idea what you lot call them but we call them Window Scrapers.
I am after some info please on the outer trim that fits between the door & the glass on a 3.2 Carrera. Do they fit all of the way from the door frame to the 1/4 light or is there a gap? Both of the ones on my car have a gap of about 1/2" or so.
Ant pics would be great
Ta muchly.
Old 02-13-2017, 09:59 AM
911 carrera 3.2 (1985)
kees's Avatar
They shrink over time.
Old 02-13-2017, 10:02 AM
Spiderman
Jesse16's Avatar
Nice little satisfying project to do replacing these. There are some threads showing before and after. I did new ones on my car after painting and the new ones are no longer gappy and with mine, they slid right in. You trim the length so I cut mine just a tad long so if they shrink they will stay fitted. Window scraper installation -- what's the secret?
This was an old thread I commented on 3 years ago, sorry but no photos. As I remember, you take off a few screwed on bits, put the window down and go at it.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 02-13-2017, 10:45 AM
Recreational User
porschenut's Avatar
This side of the pond, it's known as a squeegee (SKWEE-jee).
Old 02-13-2017, 11:43 AM
Many thanks. This has been bugging me for a while now. I will get a pair ordered
Old 02-13-2017, 12:42 PM
wrxnofx's Avatar
I installed new ones last summer and they were a perfect fit between the door frame. I did not trim them. They were the correct length out of the box.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 02-13-2017, 09:19 PM
Slowroller's Avatar
Mine need to be replaced as well. My 73 has shrunken over an inch and my 86 maybe has a 1/2 inch of right/left play. Thanks for the link Jesse16
Old 02-13-2017, 10:41 PM
wrxnofx's Avatar
The easiest way to do this is to pop the aluminum track off the car. It's held on by 6 or so metal clips. Once off, you just slide the old ones out of the track and slide the new ones in. Plus you can clean the top of the door skin while the tracks are off
Old 02-14-2017, 07:04 AM
Excellent advice as always, Many thanks
Old 02-14-2017, 10:39 AM
Occasional User
Cook&Dunning's Avatar
Does anyone have a photo of this process? Wondering how to pop off the clips, or screwed on bits? Much appreciated
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 02-14-2017, 03:47 PM
Well, I have just fitted the one's that arrived today from Design 911. What an easy job. 5 mins per side & they are perfect. No cutting/trimming needed
Remember trying to fit these to my old MK1 RS2000...... Nightmare job to get right.
As long as all jobs on the 911 are this easy then, Happy days
Old 03-03-2017, 11:29 AM
Vintage Owner
Jack Stands's Avatar
The trim is held on by metal clips. Just gently start lifting and they'll come out quite easily (I had no trouble about bending te trim when I did mine). Clean and slide the new rubber scraper into the channel and pop it back on the door.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 03-03-2017, 03:06 PM
RFP RFP is offline
RFP's Avatar
Well, I have just fitted the one's that arrived today from Design 911. What an easy job. 5 mins per side & they are perfect. [ snip ]
Oh, just you wait 'till you replace the darned seal around the front, fender-mounted oil cooler! Sheesh...
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 03-03-2017, 03:23 PM
That good eh?
Old 03-04-2017, 11:26 AM
shinrai's Avatar
Looking to do this too. Can anybody provide the part number for the rubber scraper that typically shrinks over time? It's for an '87 911. There's a few dozen seals that all look the same.
TIA
'87 911 GP White "casper"
'79 930 Copper Brown Metallic "beast"
'93 968 Amazon Green Met "moby"
'97 Esprit V8 "flat eric"
'97 993 Speed Yellow "tbd"
Old 08-08-2017, 06:31 AM
shinrai's Avatar
Found this on the www:
"You need to order left and right
Left: 911-531-931-02-M136
Right: 11-531-932-02-M136
Replacement was very easy, the steel black strip just pops up with minimal force and allows you to slide out the rubber strip which is covered with felt on the inside.
WD-40 into the rail to allow the rubber to slide in and pop the steel strip back in.
5 minute job."
Old 08-08-2017, 11:54 AM
wrxnofx's Avatar
You'll want item 10 in this image:
Here are the part numbers (they are different for the Coupe versus Targa/Cabrio). Also, the left is different than the right:
So your part numbers that you listed are correct for a Coupe.
Item 11 is a different strip that goes underneath the front triangle window.
Item 13 is the metal strip that you have to pry up off the door.
Item 8 is the little springs that are attached to that metal strip that hold the metal strip in place. There are 7 per strip I believe.
I don't know that I'd say it's a 5 minute job, but it's not longer than a 15 minute job per side. I didn't need any soap or anything to put the new ones in or take the old ones out.
Old 08-08-2017, 01:51 PM
