dsmyth's Avatar
Removing temp sensor on 85?
This little puppy does not want to come out. Looks like someone has already chipped a fin below trying. Does the black connector unplug? Do they usually get this tight? I am going to remove the tin and try again. Any suggestions. thanks Doug Its coming apart nicely except for this so far!!
Doug
97 C2S 993(last one)
95 993 cab- 85 911 M491
87 944 Turbo- 70 914-6
63 911
Old 01-13-2010, 09:27 PM
a.k.a. G-man
Geronimo '74's Avatar
I was just trying to figure this out myself yesterday....
Spanners are to big, needle nose plyers can't get enough grip. (that sucker is screwed in good and tight!!)
I think I am going to adapt a spanner (the "ring" type) so that I can get it over the wire.
All I need to do is make a gap in the ring portion of the spanner so the wire can get in. (sorta like a crow's foor spanner)
Old 01-13-2010, 10:04 PM
175K911's Avatar
If you're replacing the sensor, just cut the wire off and use a good 6-point deepwell socket. I modified a SnapOn 14mm deep well by cutting a thin slot up the side for te wire to poke out of when installing. (I first modified a cheaper Craftsman socket but it flexed tto mucy trying to get the sensor out.) My feeling though is that this is a weak link in our cars and should always be replaced whenever the engine is out since it's a bear to get out with the engine installed.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 01-14-2010, 03:44 AM
dshepp806's Avatar
Lotsa' Kroil !!!!!!
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-14-2010, 03:52 AM
