What are the sysmptoms when a throttle switch fails?
Hello all. Just curious what the tell tale signs are when the throttle switch goes. I have a flat spot at between 2500 and 3k rpms. It runs normal fter that range and if I drop back down the flat spot appears again.
Thanks,
Chris
Chris
95 993 C2
84 911 gone to to a new home
Old 01-18-2010, 01:01 PM
Jupiter 911
bklyn's Avatar
Chris, I noticed there was just lack of pull around 3000 rpm,s adjusted my throttle linkage and when I replaced the switch and bench checked it. The switch was intermitent, replaced the switch and the car came alive.
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 01-18-2010, 01:12 PM
Thanks bklyn. I will replace the switch then. Is a direct replacement or do you have to do any adjustments afterwards?
Thanks,
Chris
Chris
95 993 C2
Old 01-18-2010, 03:14 PM
