rear alignment
I searched through the forums but couldn't find or understand how I should fix this issue so here it is
This drawing shows the current situation of rear left hand side tyre of my 84 targa. The amount of mis-alignment is about 4 mm for each issue. What I understood is I can fix this by some alignment but I guess it is a very tough job. Can you help me through this?
I found this thread for reference but I guess it doesn't cover my problem, or I just cant understand.
Rear wheel toe in question
Old 01-29-2010, 01:21 AM
porsher
aston@ultrasw.c's Avatar
left rear
you have toe in and positive camber
what about the other corners?
to adjust these, Flieger's picture (in the linked thread) tells you everything you need to know!!
Obviously the devil is in the details. Get yourself a manual if you haven't already. You will need some special tools (available from pelican) and some measuring equipment try pegasusautoracing or racerpartswholesale
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 01-29-2010, 07:37 AM
Max Sluiter
Flieger's Avatar
You have a desireable alignment. You want a little rear toe-in and a good amount of negative camber. This is what I interpret your diagram as showing.
Old 01-29-2010, 04:15 PM
porsher
if *both* pics are the LH rear then i think we have positive camber, which is not good at all.
/-------\ good
\-------/ bad
79 928 Race Car
Old 01-29-2010, 04:54 PM
rnln's Avatar
how about |--------| ? Maybe a little tiny bit of (-) camber.
/-------\ good
\-------/ bad
Fat butt 911, 1987
Old 01-29-2010, 05:07 PM
both pics are showing the rear left tyre. Front and bottom of the tyre is looking inwards not straight ahead.. This effects the ride badly for sure.
Old 01-31-2010, 12:30 PM
