"Charlie" Sway bar Question / Help
Hey Gang,
I purchased my 1987 911 3.2 with what I am told are "Charlie" sway bars. From what I have read, these are really good sway bars and are no longer made? Can someone confirm that? Secondly, there is a lot of squeaking noise emminating from what I believe is the sway bar. I took the wheels off and took a look around. The bar itself spins and I cant tell if there is some sort of bearing or a bushing etc. I can't take the plate cover off of the bar without dropping the gas tank so I could not go in for a look. I tried greasing it but not sure how much grease I was able to get in given that I could not take the plate off. Is anyone familiar with these sawy bars? The same noise is emminating from the rear of the car so I suspect its the same problem. If there are bushings I need to replace, can anyone tell what parts to buy and where? etc. Thanks so much for the help gang!
Gerry ____________________________________ 1987 Porsche 911 - OEM 930 Steel Wide Body 2008 BMW X5 2010 Toyota Tundra 5.7L CrewMax |
Gerry,
Charlie bars were made by Wrightwood Racing and yes, they are long discontinued. Excellent products!!!!!! Sounds like the bushings may be worn out (or dry) and require either replacement and/or relubrication. You will need to remove the bushings to inspect them as well as lube 'em with a good synthetic grease. I don't have any spares here but I'd look at McMaster-Carr.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Anybody have a front bar "wrightwood" old style sitting around?
I have them on my car front and rear and am thinking of replacing them, No issue, just going to blade type
'75 Carrera, It's stock, I swear, scouts honor! |
Thread Tools | |
Rate This Thread | |
