1969 912 (2.4l 1973.5)
ppanagis@gmail.'s Avatar
Send a message via Skype™ to ppanagis@gmail.
Transmission Serial # verification
Can anyone tell me what year?
if it is really a five speed
and if it is really a 71?
237791, 902/1
Old 02-21-2012, 10:10 AM
andrew15's Avatar
The 902/1 is an earlier gearbox - I think it's a 5-spd
The 5-spd 70-71 transaxle should be a 911/01
Regards,
AM
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 02-21-2012, 03:06 PM
83 911 Production Cab #10
JJ 911SC's Avatar
0 Series, 64-67
902/1 should be post July 65
5 Speed
If there is a 0 in front of the 1 as in 902/01, it would be a 68 5 speeds
Who Will Live... Will See
Old 02-21-2012, 03:57 PM
JJ 911SC's Avatar
Originally Posted by Eveline198029 View Post
Will see what?
Nothing if you are dead...
Old 02-21-2012, 05:19 PM
djpateman's Avatar
Originally Posted by ppanagis@gmail. View Post
237791, 902/1
1967 912 5 speed A F M S X gears
There should be a date code on the main case next to the diff side cover, what is the date?
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 02-22-2012, 08:57 AM
that is the issue i have not seen the Transmission yet... I found it odd that a 902/1 was out of a 1971 911? i will see the transmission today. I was under the impression that 1970 1971 has 911 transmission with the black case. when i was told it was a 71 alarm bells went off... am i right to question?
Old 02-22-2012, 09:25 AM
ok so it's a 67 transmission... now that all makes sense.
Thanks for your input Guy's
Old 02-22-2012, 10:29 AM
djpateman's Avatar
A 911 (70 & 71) has a mag case. The 901 you will see has an aluminum case. Mid 68 and all 69 901 cases were mag. You have to watch for compatible output flanges. Clutch actuation is different, so a 901 & 911 are not interchangeable without some work. Not sure that it would be worth the effort. Easiest to change the guts in this case.
Addicted since 1975
Old 02-22-2012, 10:59 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
You can use a 911 trans in place of a 901 if you drill and tap the pivot point for the throw out arm in the correct place so that you use the push type arm of the 901.
Remember to plug the original hole with a screw in plug.
Bob
Bob Hutson
Old 02-22-2012, 11:02 AM
So I started the install and realized that the output flanges were incompatible, so any way I can use the 4 bolt 2 pin flange on my 67 6 bolt transmission?
Old 04-25-2012, 07:11 PM
