1969 912 (2.4l 1973.5)
Transmission Serial # verification
Can anyone tell me what year?
if it is really a five speed and if it is really a 71? 237791, 902/1 |
The 902/1 is an earlier gearbox - I think it's a 5-spd
The 5-spd 70-71 transaxle should be a 911/01 Regards, AM
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
83 911 Production Cab #10
0 Series, 64-67
902/1 should be post July 65 5 Speed If there is a 0 in front of the 1 as in 902/01, it would be a 68 5 speeds
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 02-21-2012 at 04:03 PM.. |
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
1967 912 5 speed A F M S X gears
There should be a date code on the main case next to the diff side cover, what is the date?
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
that is the issue i have not seen the Transmission yet... I found it odd that a 902/1 was out of a 1971 911? i will see the transmission today. I was under the impression that 1970 1971 has 911 transmission with the black case. when i was told it was a 71 alarm bells went off... am i right to question?
ok so it's a 67 transmission... now that all makes sense.
Thanks for your input Guy's |
A 911 (70 & 71) has a mag case. The 901 you will see has an aluminum case. Mid 68 and all 69 901 cases were mag. You have to watch for compatible output flanges. Clutch actuation is different, so a 901 & 911 are not interchangeable without some work. Not sure that it would be worth the effort. Easiest to change the guts in this case.
You can use a 911 trans in place of a 901 if you drill and tap the pivot point for the throw out arm in the correct place so that you use the push type arm of the 901.
Remember to plug the original hole with a screw in plug. Bob
Bob Hutson |
So I started the install and realized that the output flanges were incompatible, so any way I can use the 4 bolt 2 pin flange on my 67 6 bolt transmission?
