Injectors serviced - lesson learned
For anyone thinking about it, I decided to send my injectors out for cleaning and figured I spend a little more for the extra tests. I also figured I go local just in case, but I may have sacrificed some service.
On the good side, I got the service turned around in about 2 weeks - they were cleaned and tested with a report furnished to me. The o-rings and screen were replaced, and I found out I had no issues performance-wise. All original parts were returned. On the other hand, I'd mailed them insured which proved to be a problem because this required the recipient to sign for them - which required a visit to the Post office counter (down the hall from his PO Box). I thought this would be easy, but I had to wait almost a week for them to be picked up - I had to ask a couple of times. ![]() I neglected to compare all services between shops - learned painting isn't part of the service. And - I didn't get new pintles - the excuse here was that they had problems with the "new ones falling off". I requested new ones to be mailed (still waiting). Anybody ever hear of pintles falling off? Can I securely replace'em myself? Before and after shots... ![]() ![]()
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
I had mine done two years ago. I took them down to a local shop in the morning, picked them up in the afternoon. New filter basket, pintle, spacer, O-ring. $25.98 plus taxes each. No mention of the pintle falling off. I wouldn't know anything about putting the pintle needles on yourself, but someone else here might chime in.
Henri '87 Carrera coupe: Venetian blue |
Formerly known as Syzygy
Where did you take them, Henri?
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
I took them to West Coast Turbo in Richmond. Near the Olympic speed skating oval (that's only relevant because the Olympics kick off tonight). Their web site is wcturbo.com
Thanks.
So the big party is starting tonight. Good luck with that. I have friends strongly suggesting that I make a little trip out for a bit to experience the event. I just might drive down for a couple days. One doesn't often get an opportunity like that.
just me
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
Guess I can't complain, these were about $21.00 if you include shipping.
Found another thread here regarding leaving the original pintles on, hopefully it was sound advice so I'll leave them alone considering the 'issue' and my lack of skill in this area - something about the kit containing the incorrect part.
Witchhunter.com is great for mail in service. Do them right before you need them. Cleaned injectors don't like to sit on your shelf.
I'll second Witchhunter. My injectors are on their way there right now. Past experiences with them have been excellent.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
just me
how often do you get your injectors rebuilt?
Just for the record;
witchhunter does not do CIS or so the web site claims.
Tsunamiboy 1979 911 SC (3.2L) 1997 Boxster 986 |
I had my injectors serviced, they were sent out by a shop that does a lot of speed/track work. He had the flows on the injectors and marked the cylinders that I was to install them in. Steve said that some cylinders will run hotter or colder than others so he matched the injectors to the cylinders as best he could. It wasn't rocket science, but every little bit helps...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Mitch,
How do they match according to temp? Spray patterns? Interesting.... Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
I got my injectors cleaned whilst doing a rebuild, took three different shops to do it properly.
The first one sent them back with a pintle cap missing (and did not replace the filters, seals or caps). The second sent a report but did not change the seals or pintle caps. The third guy actually cleaned and tested them properly and replaced the filters, seals and caps (as all of them had been requested and agreed to do). Mr Injector in the UK is the only person to use. Stay away from Fuel Injection Centre in Cheshire. |
Doyle,
I'm not sure what the criteria was, other than my guy had the injectors marked for which cylinders they went back in. I believe he said that traditionally some of the cylinders will run hotter than others so you would install the "wettest" (?) injector in that hole. Maybe somebody can jump in here and be more articulate on the subject than what I'm saying.
That makes sense on paper. If an injector flows more fuel, it could keep a hotter cylinder cooler than a leaner injector.
Thread Tools | |
Rate This Thread | |
