Installing a mechanical brake light switch Q
For those who have done this. Which wire/wires on the brake light switch do you splice into.
I have an 1981SC which has three prong switches on the MC? Read some articles on this with some good pics but none on the MC switch wires. I want to make sure I'm doing it right. Thanks Barclay |
Senior Advisor
Can't you just splice into the brake light wire in the engine compartment?
08 Cayenne Turbo |
N-Gruppe doesn't exist
hey i'm tailgaiting for a reason....your going too slow!!!!!
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
Happiest when Tinkering
I am not at home right now but if you have a wiring diagram you can figure out the wire that goes back to the brake light and what I did is unplug one of the plugs off the master cylinder and plug one wire into the feed to the supply at the plug and run it down to the switch and then the other side of the switch back up to the side of the plug that goes to the brake light. The feed will have 12 volts on it constant the other wont but if you run a jumper to the battery will turn on the brake lights.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me Last edited by gsmith660; 03-11-2010 at 04:42 PM.. |
