Buck Nasty
xxultramistersi's Avatar
Tow Hooks are Expensive!!!
I was searching for tow hooks earlier today and I did not realize how expensive they are! For just a loop of metal it is $100, and you first need to buy the specialized mounting bracket. Am I not looking in the right places? And do I even need to get a specialized mounting bracket? The car in question is a 1989 Carrera 3.2
"I couldn't find the sports car of my dreams, so I built it myself"-Ferdinand Porsche
1989 Carrera 3.2 Coupe
1996 Carrera 4 Cabrio
Old 02-17-2010, 09:15 PM
Britain Smith's Avatar
Have you seen this one from Rothsport? It is only $49 and I have seen it on several cars around here and looks to work great.
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 02-17-2010, 10:56 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
How will that mount along with the normal 911 muffler at the back - is there still space?
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 02-18-2010, 02:45 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
I got this one from Paragon. A bit of a PITA to bolt on with the muffler in place but the payoff is it acts as a jackpad also.
Tow Eye & Jack Pad, 911 Rear $59.95
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 02-18-2010, 06:10 PM
muck-raker
kidrock's Avatar
made of 100% pure Unobtanium, no doubt.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-18-2010, 06:47 PM
Walt Fricke's Avatar
The problem with all of these engine mount tow hooks is that the idea is for the tow truck to snatch your half buried car out of the gravel trap expeditiously. The tow truck driver doesn't want to have to dig a tunnel in the gravel to get to it. Some race venues even specify a minimum height off the ground, though PCA does not.
The cheapest rear tow hook for a 911 is the factory one, which can easily be removed when not needed. Of course, if you have removed the stock bumper you can't really use that.
Old 02-18-2010, 08:34 PM
Formerly known as Syzygy
Canada Kev's Avatar
Do you know if this can be used with the factory heat exchangers (Carrera) and muffler (or similar like an M & K)?
Kevin
Old 02-18-2010, 09:38 PM
Old 5 point harness.....zero cost!
'02 6GT2 - Weekend toy
'04 6GT3 - Track weapon
'13 Cayenne GTS - Daily duty
'77 Yamaha RD 400 - Wheelie machine
Old 02-19-2010, 05:00 PM
SCOTITUDE's Avatar
I dont think the HE's are an issue. I have it installed under a monty can and getting the bolts in from the front are the PITA. The little triangle side walls inhibit a wrench in from the side. not impossible, just a PITA.
2008 E93 M3 DD
Old 02-22-2010, 08:30 PM
dshepp806's Avatar
Where does that rear tow hook mount?
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-23-2010, 05:53 PM
Things are a lot easier for those of us in the LeMons series. We developed this high tech combination trailer tie down/tow hook.
http://fast1.onesite.com/my.speedtv.com/user/richardnew/large/c6a4125fa9cb54bbc30cf5cbc03a8a6e.png?v=105315
Richard Newon
Intervention Motorsports
Our Speed TV Blog
Old 02-23-2010, 06:22 PM
